Good day all.
As per the topic title, is it possible to timestamp the recordings in milliseconds?
Thanks for your time.
Best Regards.
Is it possible to timestamp in milliseconds?
Re: Is it possible to timestamp in milliseconds?
You can add a .%f to the end of the seconds to get XX.xx seconds.
Example
%N - %y/%m/%d %H:%M:%S.%f
Its a StrfTime format if you want to look into other options.
Example
Thanks, thats just what I needed to know.
Best Regards.
Best Regards.
