I'm about to setup an installation on an atom dual core box. I don't want to spend too much money, but would prefer to get 1280x1024, if possible. Either USB or network access would be fine.
This will go onto a CentOS 6.3 system.
Thanks in advance.
JBB
Looking for recommendation for inexpensive camera for ZM
Re: Looking for recommendation for inexpensive camera for ZM
1280x1024 and inexpensive ? I guess it will all depend on what you think expensive is? For me $30 is an expensive camera so I get those cheapo Harbor Freight cameras when they are on sale and I have a 20% off coupon.
Did you have a hunt at store.bluecherry.net
evil doers beware, someone is watching you,
hopefully me!
hopefully me!
Grandstream GXV3611 HD. Great cameras. POE. Easy to use with ZM. HD resolution that you mentioned. Be warned that the resolution you mentioned will take a lot of HD to store. It's great if you have the space, but most of mine just run at 640x480 for speed and HD space.
Grandstream has a demo feed on their page for each camera model.
- spiritwalker
Even the cheap ($12) spy cam with audio mic from ebay works with my ImpactVCB capture card on ZM1.25
