I am trying to install ZM on my Debian Squeeze environment, but I keep getting a mysql install error when I try to install ZM from the repo.
This is what I'm getting:
root@DiskStation:/# apt-get install zoneminder
Reading package lists... Done
Building dependency tree
Reading state information... Done
zoneminder is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Can not write log, openpty() failed (/dev/pts not mounted?)
Setting up mysql-server-5.1 (5.1.49-3) ...
Stopping MySQL database server: mysqld.
121124 7:54:55 [Note] Plugin 'FEDERATED' is disabled.
121124 7:54:55 InnoDB: Started; log sequence number 0 44233
121124 7:54:55 InnoDB: Starting shutdown...
121124 7:55:03 InnoDB: Shutdown completed; log sequence number 0 44233
df: Warning: cannot read table of mounted file systems: No such file or directory
Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed!
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing mysql-server-5.1 (--configure):
subprocess installed post-installation script returned error exit status 1
configured to not write apport reports
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.1; however:
Package mysql-server-5.1 is not configured yet.
dpkg: error processing mysql-server (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of zoneminder:
zoneminder depends on mysql-server; however:
Package mysql-server is not configured yet.
Package mysql-server-5.1 which provides mysql-server is not configured yet.
dpkg: error processing zoneminder (--configure):
Errors were encountered while processing:
mysql-server-5.1
mysql-server
zoneminder
