I really think my question is stuped, but, i can't find the answer.
I create a Monitor-1 with the Function Record, on /dev/video0.
Ok, it got the images.
But all files got the name xxx-capiture.jpg.
The only thing i neeed is change this to 24h_File.mpg or swf or avi and i cant find how to do this.
So if someone can tell me how the zoneminde change the files(configurarion), or if that need be done by hand(Cron).
I got the ffmpeg 0.65
Zoneminder 1.25.0.
Thanks.
Events(Save format).
Re: Events(Save format).
essemesmo wrote:Hello,
Zoneminder 1.25.0.
Thanks.
Hello Essemesmo,
There is a way to get this done, but not as requested by a convertion of your recorded images.
See post: http://www.zoneminder.com/forums/viewto ... deo#p74373
I hope feature fits your needs!!
Kind regards and success, Christo
