ZM Homepage not running - after moving to other folder
sauermyg
Post by sauermyg » Tue Jul 24, 2012 11:24 am
Hello everybody,
I had a running zoneminder configuration since last year. With two cams.
Because of the current disk space I tried to move it elsewhere. Now I couldn't
restart the homepage (empty page in the browser).
I did the following steps:
1. /srv/www/httdocs/zm --> /raid1/srv/www/httdocs/zm
2. changed the location in the apache config file
3. changed the path in rczm start command and config files
restart apache, mysql, zm
--> empty page nothing happens
If I copy a standard index.html to e.g. ../httdocs/test and open this page I see this page in the browser (192.168.178.x/test).
So apache is running fine. I reinstalled zoneminder (Suse 11.4) with yast (Zoneminder Version 1.24 -> 1.25). Zoneminder installed the web-files to the standard folder /srv/www/httdocs/zm. I moved them to /raid1/srv/www/httdocs/zm. I changed everything (zm.conf, rczm start command, user rights, etc.) and I still have the same problem -> empty page. I started mysql and droped the zm database. I made a new database with no errors. I restarted zm and can see the deamon zmc, zmupdate etc.. The mysql server is running fine.
So, what can I do? Wher is the problem? :oops: :?
Markus
usersenior
Re: ZM Homepage not running - after moving to other folder
Post by usersenior » Tue Jul 24, 2012 5:25 pm
you have disabled selinux?
You changed the permissions of the web directory zm?
sauermyg
Post by sauermyg » Tue Jul 24, 2012 6:48 pm
Hello!
What do you mean with: you have disabled selinux?
Here are some screen shots.
Thanks!
Markus
Jeffrey
Post by Jeffrey » Wed Jul 25, 2012 8:40 am
We means your firewall configuration. The name of the 'program' that is controling it is called SELinux
Google -> Disable SELinux
usersenior
Post by usersenior » Wed Jul 25, 2012 10:48 am
which distribution of linux are you using?
Change owner and group of files this directory for user of apache
monex
Post by monex » Sun Sep 02, 2012 2:38 pm
If you are moving the ZM Web folder to a different directory you have to adjust the apache2 configuration too. Have a look at /etc/apache2/conf.d/zm.conf and change the directory so that it matches you new directory.
Hope this helps
