New zones in 1.25
Posted: Fri Jun 29, 2012 8:06 pm
Hi there. I've switched to 1.25 to get better memory handling and HD support. While my CPU usage goes through the roof when ZM is running (and that is always), the rest with 1.25 has been manageable.
One thing is that I'm running into issues creating new zones. The zones I now have were created with 1.24 and those trigger fine in .25. But trying to create a new zone or modifying the existing .24 ones is not working as expected. I go through the process to add a new zone put cannot see the zone red 'mesh'; only four dots at the corners. I can move the dots but the mesh never shows. Modifying an existing .24 zone has the same problem. Any hints?
Thanks,
JR
Thanks,
JR
