Trouble starting ZM 1.25 on Ubuntu after latest updates
kmk
Post by kmk » Mon May 07, 2012 10:21 pm
My zoneminder installation seems to have stopped working after installing the latest updates for ubuntu. I can get to the web interface fine, but it will not start recording. I've upgraded to 12.04 hoping it would resolve these issues, however I'm still getting the same errors:
Starting ZoneMinder: Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/bin/zmpkg.pl line 159.
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/bin/zmpkg.pl line 158.
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/bin/zmpkg.pl line 160.
Execution of /usr/bin/zmpkg.pl aborted due to compilation errors.
failure
Any guidance is appreciated.
nightcrawler
Re: Trouble starting ZM 1.25 on Ubuntu after latest updates
Post by nightcrawler » Tue May 08, 2012 9:13 am
Did you check if your configtable at the ZM database is still complete with the settings?
I had an simular issue after an few updates.. and somehow the config table was empty.
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
kmk
Post by kmk » Wed May 09, 2012 10:22 pm
Yes, the config table is full, and settings seem pretty accurate.
Jim March
Post by Jim March » Fri May 11, 2012 1:23 am
Same problem here. Can't issue a start command from the ZM Console. And if I check the logs after trying, all I get is:
fetchNextLogs is undefined
Jim March
Post by Jim March » Fri May 11, 2012 1:27 am
Wait, to clarify, here's the whole log entry and it appears after a LONG pause...
Date/time: 2012-05-10 19:18:57.451305
Component: web_js
PID: 1171
Level: ERR
Message: fetchNextLogs is undefined
File: zm/skins/classic/views/js/log.js
Line: 122
That's all ONE line.
Is it possible that Java support of some sort is broken?!
