How to install
frankge973
How to install
Post by frankge973 » Mon Apr 16, 2012 3:21 pm
I downloaded package but when I give make install a lot of errors appears.... (variable not configured... etc.)
I've newer to Linux OS, but version 1.24 did'nt required a lot of set-up
nightcrawler
Re: How to install
Post by nightcrawler » Mon Apr 16, 2012 7:00 pm
dear friend,
please do a little search before asking..
look at the dozen wiki topics and forum postings about new zm 1.25 installs.
like : http://www.zoneminder.com/wiki/index.php/Ubuntu
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
frankge973
Re: How to install
Post by frankge973 » Tue Apr 17, 2012 8:09 am
I tried but when I try to compile a lot of errors appears saying that some variable is not declared etc.
zm_mpeg.h:43:7: error: use of enum 'PixelFormat' without previous declaration
zm_mpeg.h:44:2: error: 'AVOutputFormat' does not name a type
make[2]: *** [zmc.o] Error 1
I installed all prerequisites.
SO is Ubunutu 11.10
PacoLM
Re: How to install
Post by PacoLM » Tue Apr 17, 2012 3:56 pm
mkdir /usr/src/zm1.25
cd /usr/src/zm1.25
wget http://ftp.debian.org/debian/pool/main/z/zoneminder/zoneminder_1.25.0-1_i386.deb
## or your choice of architecture in http://ftp.debian.org/debian/pool/main/z/zoneminder/
dpkg --install /usr/src/zm1.25/zoneminder_1.25.0-1_i386.deb
If complains, install the needed packages. Hope it helps,
PacoLM
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
clara22
Re: How to install
Post by clara22 » Wed Apr 18, 2012 12:12 pm
Thank you for information.
likeaboss22
Re: How to install
Post by likeaboss22 » Mon Apr 23, 2012 3:11 pm
I use the surveillance system in my business coaching BH, and whoever wants opinion on the subject
For viewing the videos Zoneminder uses an overlay images jpegs that runs by default in Mozilla Firefox browser. If you use another browser to see your videos it will also work, but with a very low FPS. To resolve this problem, we can use Cambozola which is a small and lightweight java application that solves the problem once.
After this step already done the steps on the command line, now let's move on to the browser. Enter in your browser (I recommend using Firefox) to access your server ZoneMinder.
The first thing I recommend doing is to add a little security.
To do this go to options and check OPT_USE_AUTH. With this you will need to enter username and password (User admin and password admin is the default). If you prefer to change LANG_DEFAULT en.
cambot
Re: How to install
Post by cambot » Tue Apr 24, 2012 9:22 pm
frankge973 wrote:I downloaded package but when I give make install a lot of errors appears.... (variable not configured... etc.)
Since it's your first time out, I think you'd find life a lot easier if you used one of the pre-build packages based on ubuntu. There are several Wiki articles out which explain how to install a complete server including Zoneminder, step by step.
Here is a list of several of them:
http://www.zoneminder.com/wiki/index.ph ... ntu_Server
frankge973
Re: How to install
Post by frankge973 » Thu Apr 26, 2012 9:43 am
Running. The problem is that again there are orange sources.... And I really don't know way
nightcrawler
Re: How to install
Post by nightcrawler » Thu Apr 26, 2012 12:16 pm
again, read the wiki.
orange sources (not red!) means that your monitor is in monitor of "none" mode. it turns green if you set it on modect,morecord or so. Orange isn't bad, you can view your camera's if your source is working!
frankge973
Re: How to install
Post by frankge973 » Thu Apr 26, 2012 2:09 pm
nightcrawler wrote:again, read the wiki.
Yes, obviously, but the mode is Mocord and it's not green!
Source is working but it doesn't acquire because is ORANGE
douglaskgoff
Re: How to install
Post by douglaskgoff » Sat Apr 28, 2012 6:26 am
During installation process my system shut down automatically.Any help must be appreciated.
