Configure was run with the following arguments:make[2]: Entering directory `/source/zoneminder/svn/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_stream.h:27:0,
from zm_event.h:39,
from zm_zone.h:27,
from zm_monitor.h:26,
from zmc.cpp:28:
zm_mpeg.h:43:7: error: use of enum ‘PixelFormat’ without previous declaration
zm_mpeg.h:44:2: error: ‘AVOutputFormat’ does not name a type
zm_mpeg.h:45:2: error: ‘AVFormatContext’ does not name a type
zm_mpeg.h:46:2: error: ‘AVStream’ does not name a type
zm_mpeg.h:47:2: error: ‘AVFrame’ does not name a type
zm_mpeg.h:48:2: error: ‘AVFrame’ does not name a type
make[2]: *** [zmc.o] Error 1
make[2]: Leaving directory `/source/zoneminder/svn/src'
make[1]: *** [all-recursive] Error 1
./configure --with-webdir=/var/www/localhost/htdocs/zm --with-cgidir=/var/www/localhost/cgi-bin ZM_DB_USER=*** ZM_DB_PASS=*** LDFLAGS=-s CPPFLAGS=-I/usr/local/include --no-create --no-recursion
While this is svn commit 3648 from svn.zoneminder (dot) com/svn/zm/trunk (last updated several months ago), I also tried compiling the 1.25.0 tarball.checking libavutil/avutil.h usability... no
checking libavutil/avutil.h presence... yes
configure: WARNING: libavutil/avutil.h: present but cannot be compiled
configure: WARNING: libavutil/avutil.h: check for missing prerequisite headers?
configure: WARNING: libavutil/avutil.h: see the Autoconf documentation
configure: WARNING: libavutil/avutil.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavutil/avutil.h: proceeding with the compiler's result
configure: WARNING: ## ------------------------------------------------------------------------- ##
configure: WARNING: ## Report this to http://www.zoneminder.com/forums/ - Please check FAQ first ##
checking for libavutil/avutil.h... no
checking libavcodec/avcodec.h usability... no
checking libavcodec/avcodec.h presence... yes
configure: WARNING: libavcodec/avcodec.h: present but cannot be compiled
configure: WARNING: libavcodec/avcodec.h: check for missing prerequisite headers?
configure: WARNING: libavcodec/avcodec.h: see the Autoconf documentation
configure: WARNING: libavcodec/avcodec.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavcodec/avcodec.h: proceeding with the compiler's result
checking for libavcodec/avcodec.h... no
checking libavformat/avformat.h usability... no
checking libavformat/avformat.h presence... yes
configure: WARNING: libavformat/avformat.h: present but cannot be compiled
configure: WARNING: libavformat/avformat.h: check for missing prerequisite headers?
configure: WARNING: libavformat/avformat.h: see the Autoconf documentation
configure: WARNING: libavformat/avformat.h: section "Present But Cannot Be Compiled"
configure: WARNING: libavformat/avformat.h: proceeding with the compiler's result
checking for libavformat/avformat.h... no
checking libswscale/swscale.h usability... no
checking libswscale/swscale.h presence... yes
configure: WARNING: libswscale/swscale.h: present but cannot be compiled
configure: WARNING: libswscale/swscale.h: check for missing prerequisite headers?
configure: WARNING: libswscale/swscale.h: see the Autoconf documentation
configure: WARNING: libswscale/swscale.h: section "Present But Cannot Be Compiled"
configure: WARNING: libswscale/swscale.h: proceeding with the compiler's result
checking for libswscale/swscale.h... no
gcc (Gentoo 4.5.3-r2 p1.1, pie-0.4.7) 4.5.3
autoconf (GNU Autoconf) 2.68
automake (GNU automake) 1.11.3
m4 (GNU M4) 1.4.16
Linux 3.3.0-v.17:2-3-2012-04074-g5375871 SMP (x86_64)
ffmpeg version 0.10.2
libavcodec.so.53.61.100
libavutil.so.51.35.100
libavformat.so.53.32.100
libswscale.so.2.1.100
