Memory problem
eldwist
Memory problem
Post by eldwist » Wed Feb 29, 2012 6:42 pm
Hello to all.
I've installed zm following the UB11.10 wiki with no problem.
It's running on HP Z210 4Gb HW.
I've 5 cameras connected with 320*280 res.
If I change the camera res to 640*480 I've got the following error :
Got unexpected memory map file size 36865524, expected 9217524
I've search a bit, and I've done
kernel.shmall = 134217728
kernel.shmmax = 134217728
sudo init 6
But I still have the same issue and I cannot increase the resolution.
Any idea ??
Thanks in advance
Best regards
Eld
mastertheknife
Re: Memory problem
Post by mastertheknife » Fri Mar 02, 2012 6:17 pm
Restart ZM.
mastertheknife
Kfir Itzhak.
nightcrawler
Re: Memory problem
Post by nightcrawler » Fri Mar 02, 2012 10:43 pm
mmm I've got the same error. and I have an brand new ZM 1.25. install (build 3648 from SVN) on an ubuntu 11.10 server.
Got mmap configured, and also shmax on an good size...still that same error..that zm espected more memory than there is reserved.
Did some google-ing, but didn't find an working sollution (on this url is an sollution but didn't work.. )...someone any idea's?
Shared data size conflict in shared_data for monitor **** expected 328, got 316
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
PacoLM
Re: Memory problem
Post by PacoLM » Sat Mar 03, 2012 9:40 pm
Are you sure that you have modified the proper file and restarted your system?
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
Users browsing this forum: No registered users and 11 guests
