What videos encoder, audios encoder that zoneminder support?
ngochungb46
Post by ngochungb46 »
Hi everybody.
I want to know What videos encoder, audios encoder that zoneminder support?
and where can I find its documents?
Thank so much!
ngochungb46
Re: What videos encoder, audios encoder that zoneminder supp
Can you help me?
Thanks!
PacoLM
Post by PacoLM »
No audio encoder.
cordel
Post by cordel »
Default video is mjpeg stream, though if you build in ffmpeg it can stream mpeg container. Other codecs can be be used if you compile them in and add any needed bits of code in.
Audio is not supported.
