OPT_USE_AUTH - authentication enabled > now locked out...
gerfry
Post by gerfry » Wed Jan 04, 2012 3:22 pm
Dear everyone, following situation - anyone a good idea?
Situation before: everything worked, "USER" button under Options was missing > looked into manual > found OPT_USE_AUTH value to enable user management
what I did: switched the value on
result/Situation after: I was logged out and can't login no matter which user settings I try -
(support: walked through the databases where there is an admin user, but I am not sure if that's the right one to change/right place to add other users...)
Question: how do I add users in the first place (when no "USER" button is under Options) / how can I regain access to zm?
Thanks for any help
fry
DREMA
Re: OPT_USE_AUTH - authentication enabled > now locked out..
Post by DREMA » Mon Jan 09, 2012 3:53 pm
Default user/pass is admin/admin
Just... enjoy life! :D
nightcrawler
Post by nightcrawler » Mon Jan 09, 2012 4:55 pm
second: you can alter the mysql database table for the user. please look at this posting : http://www.zoneminder.com/forums/viewto ... ser#p71908
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
gerfry
Post by gerfry » Mon Jan 09, 2012 5:28 pm
Will try that - thank you very much!
fry
Users browsing this forum: Bing [Bot] and 7 guests
