RTSP Assistance
beerygaz
RTSP Assistance
Post by beerygaz »
I have a shiny new 1.25 installation and my capture card & analog cams are working fine. I can also access my Brickcom WOB-100A via http/MJEPG, but would prefer RTSP and H.264 or MPEG4.
I can access the camera using a browser on rtsp://<ip>/channel1 but when I try to configure ZM I get the following error:
Dec 28 16:04:36 dvr zms[23848]: FAT [You must have ffmpeg libraries installed to use remote camera protocol 'rtsp' for monitor 13]
I have ffmpeg installed in /usr/local/bin, I used the --with-ffmpeg=/usr/local configuration switch and I have modified the path in the ZM options page.
If I set the camera to H.264 instead of MPEG4 then I get the following errors in my log:
Dec 28 16:14:07 dvr zmc_m13[23939]: ERR [Error while decoding frame 0]
Dec 28 16:14:07 dvr zmc_m13[23939]: ERR [256: 5c 81 9b 98 02 bd ca 30 7c e5 bc b6 28 d6 dc 77 c7 e3 a4 46 7e 1d 6f dc ea 88 42 30 7d 41 9a b2 7
1 d4 11 69 c1 cc 31 3a 88 fc df f1 fc 74 cd cf 09 9f fa ff 68 a7 e0 d7 e3 ee 69 59 d6 8e e9 96 d9 40 fc 4c b7 ec 58 d9 ea bf 09 c3 a9 3e dc 96
31 0a 82 31 62 2f f8 99 4a c3 1f 47 07 b1 16 9f 88 b3 a6 63 2c 43 2e a8 36 1e f1 16 99 82 a6 3b 13 63 63 e9 78 f9 8d 40 d4 08 1d 0d 91 6a 83 f1
b4 7f 8e e3 2d cc e9 c0 44 a3 b5 d2 a2 a7 e4 8e 55 c6 1a 71 78 4a 1d 42 ed c0 b4 34 34 32 5c 17 93 39 21 f8 ad 4b e3 3c cd 3a 52 a2 85 47 29 f
5 13 1a 2c ea 10 28 fc 4c ed e8 60 7f 59 e8 24 bc 64 85 73 a5 b3 63 9f e5 99 8a a3 aa b6 fc 66 c4 52 c6 4f 55 27 7b 58 70 3c f5 26 d9 cc df 37
19 6f fc 7e 9b 63 a2 95 8c 7c bc 82 80 d9 b1 9f d3 f1 73 6f f1 e8 95 cd 1c 4b a5 d7 72 16 a0 87 e2]
Any ideas on troubleshooting would be much appreciated. Is there any more detail I can provide to help identify the issue?
Gavin
Mad Professor
Re: RTSP Assistance
Post by Mad Professor »
Did you get this problem sorted?
beerygaz
Re: RTSP Assistance
Post by beerygaz »
Nope, stuck with MJPEG right now, which seem to be a slower frame rate and more bandwidth intense. Any advice?
Stasiks
Re: RTSP Assistance
Post by Stasiks »
I have the same problem :cry:
Have you managed to solve this problem?
mastertheknife
Re: RTSP Assistance
Post by mastertheknife »
The RTSP mode is old and sometimes broken. You can try the ffmpeg mode instead.
mastertheknife.
Kfir Itzhak.
czjaromir
Re: RTSP Assistance
Post by czjaromir »
I have a similar problem. I have installed pc with connected cameras. Like a lot of access to debugging. This should also be extended to support for HIKVISION cameras. :shock:
