modect question
Snaki4
modect question
Post by Snaki4 »
Good afternoon,
Is there any possibility to add delay for modect recording, like drop all frames 1 min before and 1 min after movement detected?
Thanks.
bb99
Re: modect question
Post by bb99 »
Try lowering the pre and post buffers on the buffer tab of the monitor. Could be 0/0 is what your looking for although not very practical. You will end up with many events where only one was before and your first frame will be the motion that triggers the alarm. Play with those settings to get what you want.
Snaki4
Re: modect question
Post by Snaki4 »
bb99 wrote:Try lowering the pre and post buffers on the buffer tab of the monitor. Could be 0/0 is what your looking for although not very practical. You will end up with many events where only one was before and your first frame will be the motion that triggers the alarm. Play with those settings to get what you want.
Thanks for the help
bb99
Re: modect question
Post by bb99 »
You're very welcome! What settings did you settle for? Could be very helpful for others searching the forums with a similar question.
