Changed the port from webmin, now cannot access zoneminder.
GrangerTech
Post by GrangerTech » Fri Oct 21, 2011 3:59 pm
I changed the port from the webmin control for the virtual server thats used for zoneminder, now i cannot access zoneminder on that port (I used port 81) as port 80 seems to be blocked by time warner, i did the port forwarding and for some reason I cannot connect to it.
Is there something else I need to do? Do i need to tell apache to listen on port 81 as well? I looked through documention and I couldn't figure out what my issue was.
Any help?
reyes136
Re: Changed the port from webmin, now cannot access zonemind
Post by reyes136 » Thu Nov 10, 2011 8:28 pm
Must be changed in the "Existing virtual host" for "Virtual Server" and also in the "Global configuration" tab -> "Networking and Addresses". then all should work. I had the same problem.
