How to change mapped memory?
gmar_87
Post by gmar_87 » Tue Sep 13, 2011 11:26 am
I am trying to get some spare USB webcams working with ZoneMinder, but having some problems. I can get one sort of working at 320x240 but if i increase pixels or image frame size i get the following in the syslog.
2011-09-13 19:39:41.584021	zma_m2	2087	ERR	Got unexpected memory map file size 23041284, expected 5761284	zm_monitor.cpp	364
Is it possible to increase mapped memory? If so, how?
gmar_87
Re: How to change mapped memory?
Post by gmar_87 » Tue Sep 13, 2011 12:06 pm
I installed ZoneMinder 1.25.0 with
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin \
ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser \
ZM_DB_PASS=zmpass ZM_SSL_LIB=openssl --enable-debug=no \
--with-webgroup=www-data --with-webuser=www-data --enable-mmap CPPFLAGS="-D__STDC_CONSTANT_MACROS ${CPPFLAGS}"
I just noticed --enable-mmap doesn't have "=yes". Does this mean i'm not using it..?
I added the following to /etc/sysctl.conf
kernel.shmmax = 167772160
Rebooted, but still getting
Sep 13 22:05:39 ZONEMINDER1 zmc_dvideo0[3783]: ERR [Got unexpected memory map file size 6913364, expected 9217524]
mastertheknife
Post by mastertheknife » Tue Sep 13, 2011 5:59 pm
gmar_87 wrote:I am trying to get some spare USB webcams working with ZoneMinder, but having some problems. I can get one sort of working at 320x240 but if i increase pixels or image frame size i get the following in the syslog.
You need to restart ZM after changing settings such as the resolution.
mastertheknife
Kfir Itzhak.
gmar_87
Post by gmar_87 » Wed Sep 14, 2011 8:48 am
mastertheknife
I have tried restarting zm service and rebooting the server after the changes, but still same problem...
nightcrawler
Post by nightcrawler » Sat Sep 17, 2011 8:56 pm
gmar,
Mapped memory allows you to use a special type of file as the placeholder for your memory and this file is "mapped" into memory space for easy and fast access.
To enable mapped memory in Zoneminder you need to add the
--enable--mmap=yes
switch to your configure line. IE: etc/zm/zm.conf
look if your linux has an mmap drive. usualy it is like /dev/shm. (see the wiki: http://www.zoneminder.com/wiki/index.php/FAQ for mmap)
You can check it with command:
mount | grep shm
An line is send back if you have it like :
none on /dev/shm type tmpfs (rw,nosuid,nodev,size=512mb)
look to the size! if it's less then your system RAM than Increase it with an remount command
# mount -o remount,size=1G /dev/shm
and check it again
Now set in Zoneminder options path > PAT_MAP to /dev/shm (default!) and restart ZoneMinder, to check the memory slices use "df" and relating to just ZM type
ls -l /dev/shm/zm*
(you can leave the /zm* out of it if you want to see other users of the swap space)
and if it's set you can increase your camera resolution,buffer etc. if the cam stops working restart zoneminder like mastertheknife says in his post. the mmap only increase if you restart ZoneMinder.
(It personally has takes me a few days of google-in before I found this "bug").
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
gmar_87
Post by gmar_87 » Mon Oct 10, 2011 10:39 pm
nightcrawler wrote:gmar,
--enable--mmap=yes
mount | grep shm
and check it again
ls -l /dev/shm/zm*
Thanks for the advice nightcrawler. Sorry i didn't get back to you sooner!
Can i just add --enable--mmap=yes to the end of zm.conf?
BTW, my zm.conf is in \usr\local\etc
df -h
Output =
none 1.5G 73M 1.5G 5% /dev/shm
mount | grep shm
Output = none on /dev/shm type tmpfs (rw,nosuid,nodev)
There is no size mentioned.
 ls -al /dev/shm
Output =
total 74424
drwxrwxrwt  2 root     root          100 2011-10-10 19:55 .
drwxr-xr-x 19 root     root         4340 2011-10-08 11:17 ..
-rw-------  1 www-data www-data 36865524 2011-10-11 08:45 zm.mmap.1
-rw-------  1 www-data www-data 36865524 2011-10-11 08:46 zm.mmap.2
-rw-------  1 www-data www-data  2305044 2011-10-10 19:55 zm.mmap.9
From web interface Options>Paths>PATH_MAP is already set to /dev/shm
