Control scripts not working in 1.25.0
gmar_87
Post by gmar_87 » Sun Sep 11, 2011 3:23 am
I am unable to get my existing Foscam FI8918W control scripts working with 1.25.0.
I have confirmed there are no typos and chmod 777 to all *.pm files.
Log shows:
2011-09-11 13:19:14.865596	web_php	871	ERR	socket_sendto( /tmp/zm/zms-405465s.sock ) failed: No such file or directory	includes/functions.php	2325
2011-09-11 13:19:11.943530	zmcontrol	2028	FAT	Can't connect: No such file or directory	zmcontrol.pl
2011-09-11 13:19:11.832452	web_php	869	ERR	/usr/local/bin/zmcontrol.pl --autostop --command=moveConRight --id=1=>	includes/functions.php	2325
2011-09-11 13:19:11.828610	zmcontrol	2026	FAT	Can't connect: No such file or directory	zmcontrol.pl
The same control script works fine in 1.24.4
Most of the google searches lean towards a typo in file name or path, but i have triple checked and nothing is misspelt...
linuxsense
Re: Control scripts not working in 1.25.0
Post by linuxsense » Sun Sep 11, 2011 8:06 am
You are not alone. I am having the same issue. I have not had much time to look into it but I have not seen any obvious reason for the failure.
Optimist
Post by Optimist » Sun Sep 11, 2011 9:25 am
I had the same problem.
In your FoscamFI8908W.pm file, try replacing line
with
It worked for me.
gmar_87
Post by gmar_87 » Sun Sep 11, 2011 10:19 am
Optimist wrote:I had the same problem.
with
It worked for me.
Thanks Optimist! That fixed it :)
linuxsense
Post by linuxsense » Mon Sep 12, 2011 7:28 pm
Nice find, fixes the problem for me as well. Makes sense with the new logging in 1.25. Thanks.
expertpc
Post by expertpc » Fri Mar 02, 2012 7:41 am
This also helped me fix control problems with the Airlink101 SkyIPCam7xx camera as well so thanks!
Steve B
General Manager
Expert PC
Users browsing this forum: Google [Bot] and 6 guests
