Firefox problems with ZM 1.25.0...?
gmar_87
Post by gmar_87 » Sat Sep 10, 2011 8:24 am
I have just installed 1.25.0 on Ubuntu server 11.04 x64 :), but having some problems.
The values for FPS, playback speed, etc aren't displayed in Firefox. (e.g. - Mode: Rate: x Delay: s Buffer: % Zoom: x ). Also, the event list under the camera stream is blank. Internet Explorer 9 displays correctly, but Firefox 6.0.2 doesn't and generates the following errors:
2011-09-10 18:20:10.307925	web_js	891	ERR	$clear is not defined	http://10.1.1.247/skins/classic/views/js/watch.js	112
2011-09-10 18:19:58.296117	web_js	891	ERR	$clear is not defined	http://10.1.1.247/skins/classic/views/js/watch.js	112
2011-09-10 18:19:46.326586	web_js	891	ERR	$clear is not defined	http://10.1.1.247/skins/classic/views/js/watch.js	112
2011-09-10 18:19:34.335456	web_js	891	ERR	$clear is not defined	http://10.1.1.247/skins/classic/views/js/watch.js	112
2011-09-10 18:19:25.039010	web_js	891	ERR	$clear is not defined	http://10.1.1.247/skins/classic/views/js/watch.js	112
2011-09-10 18:19:24.196329	web_js	891	ERR	$clear is not defined	http://10.1.1.247/skins/classic/views/js/watch.js	547
2011-09-10 18:19:23.383613	zms	4350	ERR	Frame send time 116 msec too slow, throttling maxfps to 10.00	zm_monitor.cpp	3392
2011-09-10 18:19:22.276433	web_js	891	ERR	handleClick.bindWithEvent is not a function	http://10.1.1.247/skins/classic/views/js/watch.js
Please help!
christophe_y2k
Re: Firefox problems with ZM 1.25.0...?
Post by christophe_y2k » Sat Sep 10, 2011 4:52 pm
Hello, i seen here something similar, maybe you can try it at no cost
http://www.zoneminder.com/forums/viewto ... ot+defined
Post Re: zm 1.25.0:Views monitor: no fps, no events. ERR: $clear
I suspect this was a case of files getting cached by your browser. It's worth mentioning that clearing the cache or doing a forced refresh is a good idea when installing a new version.
gmar_87
Post by gmar_87 » Sun Sep 11, 2011 12:33 am
christophe_y2k wrote:Hello, i seen here something similar, maybe you can try it at no cost
Thanks christophe_y2k! Clearing the cache worked.
bb99
Post by bb99 » Sun Sep 11, 2011 1:40 am
To eliminate recurrence change about:config, "browser.cache.check_doc_frequency" to a value of 1. Valid values are:
0 – Check for a new version of a page once per session (a session starts when the first application window opens and ends when the last application window closes).
1 - Check for a new version every time a page is loaded.
2 – Never check for a new version – always load the page from cache.
3- Check for a new version when the page is out of date. (Default)
Users browsing this forum: No registered users and 8 guests
