1.25.0 falling apart on Suse 11.3
sticcino
Post by sticcino » Wed Sep 07, 2011 7:26 pm
***** NOTE UPDATE *******
installed from repository, all files are installed
fresh install on suSE 11.3
downloaded and compiled 1.25, a few errors but fixed them
seems to of compiled ok and installed:
- there's no zm file in /etc/init.d - how does one start the application now ?
- the database and tables were not created, how do i create them, there is no zm_init_database script any longer
Thanks,
Johnny
monex
Re: 1.25.0 falling apart on Suse 11.3
Post by monex » Sat Sep 10, 2011 4:37 pm
it is unclear to me how you installed ZoneMinder because you wrote installed from repository and in the next sentence you wrote downloaded and compiled 1.25. Are you using the RPM or did you compile it from source?
paxx
Post by paxx » Sun Sep 11, 2011 4:56 pm
a repo install is not going to setup your sql database and other things that are necessary to configure. wget the source tar ball and run the sql script provided to create your database.
I would run an updatedb && locate zm
It may list quite a few files but should be a quick way to see if zm compiled properly. If it doesn't exists, I would remove the repo install and compile from source. If it does, cp it to /etc/init.d and chmod +x zm and try to run.
Users browsing this forum: No registered users and 5 guests
