Compile Error
garyc
Re: Compile Error
Post by garyc » Sun Sep 11, 2011 6:59 pm
OK, configure command was
then added the lines you mention above but unfortunately no change
ffmpeg output reads (I added ffmpeg-devel since sending the yum output above
FFmpeg version git-svn-r21853, Copyright (c) 2000-2010 Fabrice Bellard, et al.
built on Feb 16 2010 19:33:28 with gcc 4.1.2 20080704 (Red Hat 4.1.2-46)
configuration:
libavutil 50. 9. 0 / 50. 9. 0
libavcodec 52.54. 0 / 52.54. 0
libavformat 52.52. 0 / 52.52. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
macfloripa
Re: Compile Error
Post by macfloripa » Sun Sep 11, 2011 11:23 pm
paxx wrote:add this --with-ffmpeg=/usr/local/share/ffmpeg CPPFLAGS="-D__STDC_CONSTANT_MACROS"
and ./configure again
note: for fedora it may be just /usr/share/ffmpeg
I never used the fedora distro
bummer - thanks for the attempt... I appreciate it.
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/share/ffmpeg/include -Wall -Wno-sign-compare -fno-inline -I/usr/share/ffmpeg/include -D__STDC_CONSTANT_MACROS -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_stream.h:27:0,
from zm_event.h:39,
from zm_zone.h:27,
from zm_monitor.h:26,
from zmc.cpp:28:
zm_mpeg.h:43:7: error: use of enum ‘PixelFormat’ without previous declaration
zm_mpeg.h:44:2: error: ‘AVOutputFormat’ does not name a type
zm_mpeg.h:45:2: error: ‘AVFormatContext’ does not name a type
zm_mpeg.h:46:2: error: ‘AVStream’ does not name a type
zm_mpeg.h:47:2: error: ‘AVFrame’ does not name a type
zm_mpeg.h:48:2: error: ‘AVFrame’ does not name a type
make[2]: *** [zmc.o] Error 1
orsty3001
Re: Compile Error
Post by orsty3001 » Mon Sep 12, 2011 2:57 am
That fixed it for me.
I just had another silly problem where I didn't turn on short tags in my php.ini file.
It's all sorted now.
Thanks a lot.
garyc
Re: Compile Error
Post by garyc » Tue Sep 13, 2011 7:14 pm
Does anyone have any more thoughts from the CentOS side?
zoneminder
Site Admin
Re: Compile Error
Post by zoneminder » Thu Sep 15, 2011 8:15 am
If you manually type the command
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/share/ffmpeg/include -Wall -Wno-sign-compare -fno-inline -I/usr/share/ffmpeg/include -D__STDC_CONSTANT_MACROS -E zmc.cpp > zmc-full.cpp
then it should just run the pre-processor and include all the files it uses.
If you are able to post a link to that file via dropbox or something then I can take a closer look.
Also what is in /usr/share/ffmpeg/include? Can you just post a listing?
Phil
macfloripa
Re: Compile Error
Post by macfloripa » Thu Sep 15, 2011 11:31 am
zoneminder wrote:If you manually type the command
Interesting. No dir /usr/share/ffmpeg/include. That could explain things... Perhaps I should just build ffmpeg from source?
yum output for ffmpeg:
ffmpeg.i686 0.7-0.3.20110612git.fc15
ffmpeg-devel.i686 0.7-0.3.20110612git.fc15
ffmpeg-libs.i686 0.7-0.3.20110612git.fc15
gstreamer-ffmpeg.i686
this is on
Fedora release 15 (Lovelock)
Linux 2.6.40.4-5.fc15.i686 i386
zoneminder
Site Admin
Re: Compile Error
Post by zoneminder » Thu Sep 15, 2011 1:29 pm
Do you definitely have the ffmpeg libraries installed and not just the binary? That should have been picked up during configure but perhaps there is an issue there. What did you configure output say?
Phil
garyc
Re: Compile Error
Post by garyc » Thu Sep 15, 2011 7:59 pm
I seem to have the same issues on CentOS (now 5.7 since doing a yum update)
the g++ command returns
g++: zmc.cpp: No such file or directory
g++: no input files
I also do not have anything in /usr/share/ffmeg apart from 36 files starting lib...
ffmpeg installed using yum and returns
FFmpeg version git-86a3d7e, Copyright (c) 2000-2010 Fabrice Bellard, et al.
built on Sep 14 2011 19:19:15 with gcc 4.1.2 20080704 (Red Hat 4.1.2-51)
configuration: --enable-gpl --enable-shared --enable-pthreads
I have tried running config with --with-ffmpeg=/usr/local/share/ffmpeg CPPFLAGS="-D__STDC_CONSTANT_MACROS"
and with --with-ffmpeg=/usr/share/ffmpeg CPPFLAGS="-D__STDC_CONSTANT_MACROS"
Outputs are here http://dl.dropbox.com/u/14870257/config1.log and http://dl.dropbox.com/u/14870257/config.log
I have also tried deleting both the archive and extracted files and downloading again but no change.
Does any of this help?
zoneminder
Site Admin
Re: Compile Error
Post by zoneminder » Thu Sep 15, 2011 9:15 pm
garyc wrote:I seem to have the same issues on CentOS (now 5.7 since doing a yum update)
g++: no input files
You need to run in this in the directory that zmc.cpp is in, ie src.
garyc wrote:I also do not have anything in /usr/share/ffmeg apart from 36 files starting lib...
And they are what? This is the important part
garyc wrote:ffmpeg installed using yum and returns
Did you also install ffmpeg-devel? This is required for building against.
Phil
paxx
Re: Compile Error
Post by paxx » Tue Sep 20, 2011 3:12 am
I believe your issue is with the yum install of ffmpeg. I would yum remove the ffmpeg and the devel packages and compile from source.
Note: I did a fresh install of CentOS 5.7 i386 on a spare laptop with nothing but the core system files because I wanted to see if I encountered any errors. I followed this tutorial found here:http://www.zoneminder.com/wiki/index.php/CentOS to the T for consistency. I hit only two major snags that were easily fixed and was successful compiling zm and starting the service.
garyc
Re: Compile Error
Post by garyc » Tue Oct 04, 2011 8:28 pm
First, sorry for not coming back on your tips folks but life suddenly turned totally manic and this has to take a back seat for a while...
I have now run the g++ command from the src directory and it runs fine but I thought I should see the zmc-full.cpp file but see nothing. Have I got this wrong (again)?
here are the 36 files in /usr/share/ffmpeg are
  • libx264-baseline.ffpreset
    libx264-default.ffpreset
    libx264-faster.ffpreset
    libx264-faster_firstpass.ffpreset
    libx264-fast.ffpreset
    libx264-fast_firstpass.ffpreset
    libx264-fastfirstpass.ffpreset
    libx264-hq.ffpreset
    libx264-ipod320.ffpreset
    libx264-ipod640.ffpreset
    libx264-lossless_fast.ffpreset
    libx264-lossless_max.ffpreset
    libx264-lossless_medium.ffpreset
    libx264-lossless_slower.ffpreset
    libx264-lossless_slow.ffpreset
    libx264-lossless_ultrafast.ffpreset
    libx264-main.ffpreset
    libx264-max.ffpreset
    libx264-medium.
    libx264-medium_firstpass.ffpreset
    libx264-normal.ffpreset
    libx264-placebo.ffpreset
    libx264-placebo_firstpass.ffpreset
    libx264-slower.ffpreset
    libx264-slower_firstpass.ffpreset
    libx264-slow.ffpreset
    libx264-slow_firstpass.ffpreset
    libx264-slowfirstpass.ffpreset
    libx264-superfast.ffpreset
    libx264-superfast_firstpass.ffpreset
    libx264-ultrafast.ffpreset
    libx264-ultrafast_firstpass.ffpreset
    libx264-veryfast.ffpreset
    libx264-veryfast_firstpass.ffpreset
    libx264-veryslow.ffpreset
    libx264-veryslow_firstpass.ffpreset
ffmpeg-devel-0.6.1 is installed
does any of this help?
Cheers
Gary
