MJPEG vs MPEG for low bandwidth and CPU
TitovLab
Post by TitovLab » Wed Aug 31, 2011 10:33 am
Hello!
What is better MJPEG or MPEG for very slow and expensive IP cameras internet connection (56 kbit/s for each camera, traffic is limited) and for low CPU usage on ZoneMinder server (about 200 cameras on one server)?
netwrkr
Re: MJPEG vs MPEG for low bandwidth and CPU
Post by netwrkr » Wed Aug 31, 2011 12:55 pm
MPEG.
Flasheart
Post by Flasheart » Thu Sep 01, 2011 6:46 am
200 cameras on one server, seriously?
MPEG whilst it does use less bandwidth, uses more cpu as it needs to call ffmpeg to convert to jpg before zm touches it. Mjpeg is just a straight frame grab from a stream.
mastertheknife
Post by mastertheknife » Thu Sep 01, 2011 11:14 am
Flasheart wrote:200 cameras on one server, seriously?
Not entirely true.
For MJPEG, ZoneMinder uses libjpeg (or libjpeg-turbo) to decompress (convert into one of ZM's native formats, e.g. RGB24) the JPEG image. For a MPEG, ZoneMinder uses ffmpeg to extract frames out of the stream, and also for converting these frames into one of ZM's native formats, e.g. RGB24.
mastertheknife
Kfir Itzhak.
Flasheart
Post by Flasheart » Fri Sep 02, 2011 6:02 am
Ah, I didn't realise that. Have you done any tests to see which is faster?
netwrkr
Post by netwrkr » Fri Sep 02, 2011 2:03 pm
concur +mastertheknife.
Switching from MJPG to MPEG/H.264 *significantly* reduces bandwidth and CPU load.
developer123
Post by developer123 » Fri Sep 02, 2011 4:01 pm
So what abot H.264 (in comparison to mpeg4) would that be more expensive for the CPU? Or does that not really make a difference?
kingofkya
Post by kingofkya » Fri Sep 02, 2011 8:24 pm
Mpeg is a container
h.264 is codec
The codec goes inside the container.
gblanco
Post by gblanco » Mon Sep 05, 2011 8:33 pm
How to eliminate the delay of the data stream using MPEG? Over time the data stream is getting late. Sometimes reaches more than 1 minute late. MJPEG is practically in real time.
mastertheknife
Post by mastertheknife » Tue Sep 06, 2011 1:50 pm
gblanco wrote:How to eliminate the delay of the data stream using MPEG? Over time the data stream is getting late. Sometimes reaches more than 1 minute late. MJPEG is practically in real time.
Don't limit the fps.
mastertheknife
Kfir Itzhak.
gblanco
Post by gblanco » Thu Sep 08, 2011 5:11 pm
mastertheknife
I use NORMAL CAMERAS (NOT IP)... The data stream is not in real time after a while. It seems to me that there is a buffer.
Using JPEG (firefox streaming or camboloza streaming in Internet Explorer) streaming works great(sometime discard one or two seconds) but using mpeg streaming after while get totally late.
gblanco
Post by gblanco » Mon Sep 12, 2011 12:59 pm
mastertheknife
carteriii
Post by carteriii » Thu Dec 22, 2011 7:11 am
mastertheknife wrote:Don't limit the fps.
mastertheknife
mastertheknife, would you please elaborate on this statement?
I've always assumed that lowering the fps would help ZoneMinder and reduce the changes of big gaps in my recordings. I think this still makes sense for use with a capture card or with simple jpeg images or even mjpeg, but now I'm wondering if my assumption has been just wrong with mpeg streams. Am I actually creating more work, and risking more lag, by setting Max FPS to just 2-3fps with ZoneMinder? Does a low fps require extra work to "catch up"?
Thank you.
mastertheknife
Post by mastertheknife » Thu Dec 22, 2011 9:46 am
mastertheknife
Thank you.
When i advised not to limit the fps, i thought the user was using an IP camera. The problem with a MJPEG stream from an IP camera is that the receiver has no way to control the frame rate, so the only option to reduce the frame rate is to skip certain frames, but at the moment, ZM doesn't do this and by limiting your frame rate, you will actually get a constantly increasing delay.
Some cameras have an option to specify the maximum frame rate, e.g. maxfps=5 in the URL. If your camera supports that, thats what you should use.
mastertheknife
Kfir Itzhak.
Users browsing this forum: No registered users and 9 guests
