user zm
pystik
user zm
Postby pystik » Sat Apr 14, 2012 12:22 pm
I created a user (user) but after I restarted zm I did not choose a password, now I'm stuck on the login screen.
how can I do to reset the password?
galps
Re: user zm
Postby galps » Sat Apr 21, 2012 11:23 am
Try admin admin
pystik
Re: user zm
Postby pystik » Sat Apr 21, 2012 11:28 am
Tanks.. It is!!!
galps
Re: user zm
Postby galps » Sat Apr 21, 2012 4:13 pm
If you now go back into the Options menu, you will have an additional tab "users"
I suggest you add another user and change the default password for the admin user.
pystik
Re: user zm
Postby pystik » Sat Apr 21, 2012 4:34 pm
You know now you know how to do it , my problem was that I could not remember admin admin .
thanks so much
Return to “ZoneMinder 1.24.x”
