Accessing Zoneminder from 200 miles away
Fitch
Post by Fitch » Mon Jan 30, 2012 5:34 pm
I have a guest house which uses ZM 1.24 on an Ubuntu Jaunty system with a static IP. I am forced to leave very soon, and so have to maintain the system via remote access. I loaded Gadmin server on the ZM machine and Gadmin client on the laptop I'm taking away with me.
BT have given the guest house a static IP address (for a small monthly fee)
So far, so good..
Gadmin Server gave me two .crt files, two.key files and a .csr file, which are now sitting on my laptop desktop just looking at me. I wouldn't have the foggiest what to do with them!
At the moment I have to try and connect to the ZM machine's static IP through the guest house wifi which isn't happening, but I can connect to any other IP address on the network.
I have no chance of connecting from Edinburgh, If I can't even connect from the top bedroom.
has anybody tried something similar?
PacoLM
Re: Accessing Zoneminder from 200 miles away
Post by PacoLM » Tue Jan 31, 2012 5:24 am
The public and static IP is the address to access from the outer LAN, if you want to access the system from the local LAN you should use the local IP of the system.
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
Fitch
Post by Fitch » Tue Jan 31, 2012 9:14 am
Since I am able to access anything else on the network, I already know this..
If I access the ZM computer from any other wired computer on the network, I can also get the ZM console.
I just cannot get it from the wifi access point, and I don't know what is meant to be done with the certificates sitting on my desktop.
sgn
Post by sgn » Mon Feb 06, 2012 11:13 pm
Why are you using Gadmin (whatever it is) for remote access? As long as your ZM host has a static IP (or is connected to a router with a static IP) you can use port forwarding to access your host through http and ssh. For added security, set up a VPN solution for connecting to your home network.
You don´t even need a static IP, any dynamic DNS service (like DynDNS) will let you connect to your home network with ease.
Fitch
Post by Fitch » Tue Feb 07, 2012 12:01 am
Wouldn't have a clue what you're talking about. Sorry!
alf
Post by alf » Wed Feb 08, 2012 2:42 am
Fitch wrote:Wouldn't have a clue what you're talking about. Sorry!
There's a number of ways to do this, not many of them can be explained in detail here.
But the simple answer is forward port 80 and 22 to your zoneminder computer on your modem/router.
Then you should be able to access the zm page from anywhere, you can also protect your http pages with a password with an apache module.
You did this the hard way, a dyndns account would have been easier and cheaper.
Users browsing this forum: No registered users and 12 guests
