appropriate settings for shared memory ?
lewis
Post by lewis » Mon Nov 14, 2011 1:28 pm
hello all,
i've setup Zoneminder in a Debian GNU/Linux wheezy/sid box with 1gb ram.
i have 11 ip cameras (right now working only 6 of them) most of them 640x480 so i wanted to know the appropriate settings for shared memory..
i cannot get to work a vivotec fd6122 camera (the 7th one), i get a black screen, so i suppose its a shared memory problem..
any help would be appreciated.
Ye-Olde's Manor - http://ye-olde.net
PacoLM
Re: appropriate settings for shared memory ?
Post by PacoLM » Mon Nov 14, 2011 5:52 pm
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
lewis
Post by lewis » Mon Nov 14, 2011 7:17 pm
i run this script, gave ~900mb to shared memory, rebooted, but still no image from the camera..
i will post my problem with the right subject..
thank you anyway.
PacoLM
Post by PacoLM » Mon Nov 14, 2011 10:06 pm
Have you checked that the settings are saved in the file /etc/sysctl.conf, after the reboot?. Running the script of the first topic only shows the values, no change is done in the system.
TelegramBot
lewis
Post by lewis » Tue Nov 15, 2011 12:34 am
root@Stalin:~# ./checksharedmemory.sh
--- Checking memory setting...
-- Total memory = 1051865088 B = 1003 MB
-- Page size = 4096 B
-- Current kernel.shmmax = 946678579 B = 902 MB
-- Current kernel.shmall = 256803 pages
-- Recommended shm values already set
--- Done.
since this is a virtual server, should i give it more memory ?
for example 2gb of ram ?
PacoLM
Post by PacoLM » Tue Nov 15, 2011 5:42 am
Since is a 11 camera system, have you tried to enable them one by one and confirm that all of them work individually?. Just an idea to advance step by step and don't mix problems (if they are!).
TelegramBot
lewis
Post by lewis » Tue Nov 15, 2011 8:53 am
i gave 2gigs of memory to this host, redefined shared memory, and vivotec fd61x2 became orange, but still no image.. just a blue screen with a timecode..
PacoLM
Post by PacoLM » Tue Nov 15, 2011 4:30 pm
What is in the logs (usually /var/log/syslog ), after restarting zoneminder?
TelegramBot
Users browsing this forum: No registered users and 16 guests
