transfer ZM on a new PC
pp1981
Post by pp1981 » Tue Aug 30, 2011 1:30 pm
I'm changing computer cause to improve parformance with a CPU Core2 DUO 2.4 GHz.
Now I want to transfer all ZM software installed on the old PC to the new one.
How can I to do it without reinstall.
In particular I just installed on the old PC all the postfix for the e-mail notifier and all the other stuff of ZM.
Can I copy all the ubuntu system (or install the hard disk from the old PC on the new) or have I to copy only some specific folder?
Thank you
pp1981
PacoLM
Re: transfer ZM on a new PC
Post by PacoLM » Tue Aug 30, 2011 2:02 pm
I believe you should reinstall it. If the version is the same you could try to export the database to a file and import it in the new installation.
PacoLM
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
bb99
Post by bb99 » Tue Aug 30, 2011 11:03 pm
I use ghost for what you're trying to do (disk image to disk). Only issue I've encountered is using it on a LVM2 array. UBCD (Ultimate Boot CD) has the Linux equivalent plus a ton more tools. Linuxtracker.org has several versions available; if you need a seed let me know.
gmar_87
Post by gmar_87 » Wed Aug 31, 2011 10:51 am
Clonezilla should also work :)
pp1981
Post by pp1981 » Wed Aug 31, 2011 1:08 pm
Thanks at all,
however I chosen to reinstall it because I had some problems with the old.
I've got reinstalled all the cameras and now I have to make the zones. On your opition is there a folder that contain the zones datas (31 zone are very much :shock: and I wish to avoid to make it from begin...) ???
Thank you
Users browsing this forum: No registered users and 11 guests
