Event columns
gmar_87
Event columns
Post by gmar_87 »
When i click on the events under the "day" column it shows events from the previous day as well as today. Is this a bug of config issue?
The time on the server is correct.
I would like to see events from 00:01 to 23:59 when selecting events under the day column.
Can someone please help?
jameswilson
Re: Event columns
Post by jameswilson »
it shows the last 24 hours its not a config issue just the way it works.
James Wilson
gmar_87
Re: Event columns
Post by gmar_87 »
Thanks man
zoneminder
Site Admin
Re: Event columns
Post by zoneminder »
If you only want the events from 'today' then you can change the filter used in console.php in web/skins/classics/views and use the one from the mobile skin which is just events since midnight.
Phil
gmar_87
Re: Event columns
Post by gmar_87 »
zoneminder wrote:If you only want the events from 'today' then you can change the filter used in console.php in web/skins/classics/views and use the one from the mobile skin which is just events since midnight.
Thanks. I'll give that a go!
