Hi all
I'm trying to run ZoneMinder on a Mythbuntu (Mythtv) system. The mythtv is a solid and dependable install and I rely on the mythweb part of it constantly. As Apache is already configured through Mythtv and runs on port 80, how would I configure ZM to work - will I be able to access it and the myth web interface? I don't want to screw anything up on the Myth system as it took a while to get it the way I like it...
Do I need another port or another instance of Apache? I've also heard of people adding pages to their Mythweb to feature the Zoneminder
I don't need the mythplugin before anyone asks, I need remote access of ZM
Any help greatly appreciated
Mythbuntu 9.10 (64bit)
Zoneminder and Mythtv web access
Re: Zoneminder and Mythtv web access
Look up apache virtual hosting.
I do this myself, and have got it working on ubuntu.
If you can't work it out, I'll dig out my config files.
I suggest you make a backup of /etc/apache2 or whatever it is called before tinkering.
Well, you access you mythweb at http://ipaddress/mythweb/ or something like that, and you will access zoneminder on http://ipaddress/zm/ both on port 80, so no problem at all.
Just... enjoy life!
Thanks Kevin - I'll look into it...
@DREMA - you sure about that? I thought that the /zm or/mythweb were just redirectors for the port? If I type just the ip address, its currently goes to Mythweb anyway...
Nope, your server use the same port, those are just diferent directories.
Then your server root directory is/redirect to the mythweb, zoneminder tipically install to /zm
Just... enjoy life!
ok thanks - makes sense.
how about remote login though? can I still specify the directory for that?
thanks for your help
