BT878 card… Detected...
tibetfreedom
Post by tibetfreedom »
But does not seem to show up in zoneminder…
This may hold the clue…
Any pointers most welcome..
05:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
05:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
05:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
05:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
05:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
05:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
05:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
05:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
05:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
05:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
05:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
05:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
05:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
05:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
05:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
root@CCTV:~# dmesg | grep bttv
[    4.398969] bttv: driver version 0.9.18 loaded
[    4.398972] bttv: using 32 buffers with 2080k (520 pages) each for capture
[    4.399014] bttv: Bt8xx card found (0).
[    4.399033] bttv 0000:05:08.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    4.399646] bttv0: Bt878 (rev 17) at 0000:05:08.0, irq: 16, latency: 64, mmio: 0xfdffe000
[    4.399664] bttv0: using: IVC-200 [card=102,insmod option]
[    4.399667] IRQ 16/bttv0: IRQF_DISABLED is not guaranteed on shared IRQs
[    4.399692] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[    5.199997] bttv0: tuner type=0
[    5.231212] Modules linked in: msp3400 snd_hda_codec_intelhdmi snd_hda_codec_realtek snd_hda_intel bttv(+) snd_hda_codec snd_hwdep v4l2_common i915 snd_pcm videodev drm_kms_helper snd_seq snd_timer v4l1_compat ir_common videobuf_dma_sg drm snd_seq_device videobuf_core btcx_risc tveeprom i2c_algo_bit shpchp video snd soundcore snd_page_alloc pci_hotplug asus_atk0110 output i2c_i801 i2c_core evdev pcspkr button processor psmouse serio_raw ext3 jbd mbcache sg sr_mod usbhid hid cdrom sd_mod crc_t10dif ata_generic uhci_hcd pata_marvell ata_piix floppy firewire_ohci firewire_core crc_itu_t libata thermal thermal_sys r8169 mii ehci_hcd scsi_mod usbcore nls_base [last unloaded: scsi_wait_scan]
[    5.232522]  [<f8fff6cb>] ? bttv_init_card2+0x13fc/0x149a [bttv]
[    5.232568]  [<f8ffbff5>] ? bttv_bit_getscl+0xd/0x13 [bttv]
[    5.232725]  [<f8fffee7>] ? init_bttv_i2c+0x16f/0x1e3 [bttv]
[    5.232768]  [<f8ffdbd3>] ? bttv_probe+0x4d6/0x8e4 [bttv]
[    5.234085]  [<f900d000>] ? bttv_init_module+0x0/0xcf [bttv]
[    5.234085]  [<f900d0bb>] ? bttv_init_module+0xbb/0xcf [bttv]
tibetfreedom
Re: BT878 card… Detected...
tibetfreedom wrote:But does not seem to show up in zoneminder…
any help appreciated…
tibetfreedom
DO I need to add this somewhere … ?
If your driver is compiled into the kernel, add the following to be passed onto the kernel from LILO or GRUB.
bttv.card=0,0,0,0 bttv.tuner=4,4,4,4
I made bttv.conf file in the modprobe.d directory…
tibetfreedom
I see this in the logs…
['zmc -d /dev/video0' exited abnormally, exit status 255]
also these are the results of a couple of things, note there are only 6 camera's on the system…
root@CCTV:~# zmc --device /dev/video7
root@CCTV:~# zmc --device /dev/video5
root@CCTV:~# zmc --device /dev/video4
root@CCTV:~# zmc --device /dev/video3
Bus error
root@CCTV:~# zmc --device /dev/video2
root@CCTV:~# zmc --device /dev/video1
Bus error
root@CCTV:~# zmc --device /dev/video0
root@CCTV:~# zmc --device /dev/video6
root@CCTV:~# ipcs -m
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x00000000 0 cctvadmin 600 393216 2 dest
0x00000000 32769 cctvadmin 600 393216 2 dest
0x00000000 65538 cctvadmin 600 393216 2 dest
0x00000000 98307 cctvadmin 600 393216 2 dest
0x00000000 131076 cctvadmin 600 393216 2 dest
0x00000000 163845 cctvadmin 600 393216 2 dest
0x00000000 196614 cctvadmin 600 393216 2 dest
0x00000000 229383 cctvadmin 600 393216 2 dest
0x00000000 262152 cctvadmin 600 393216 2 dest
0x00000000 294921 cctvadmin 600 393216 2 dest
0x00000000 1933322 cctvadmin 600 4177920 2 dest
0x00000000 393228 cctvadmin 600 393216 2 dest
0x00000000 425997 cctvadmin 600 393216 2 dest
tibetfreedom
also I get this…
zmu -d /dev/video0 --verbose -V1 --query
Error, failed to open video device /dev/video0: No such file or directory
tibetfreedom
Oh and this…
root@CCTV:~# ps axf | grep zmc
9245 pts/0 S+ 0:00 \_ grep zmc
9257 pts/0 S+ 0:00 \_ grep zmc
9259 pts/0 S+ 0:00 \_ grep zmc
The PID keeps changing so maybe the deamon is crashing …?
tibetfreedom
oh and with extra debug on I got this…
05/26/11 11:00:50.082974 zmc_dvideo7[9611].INF-zm_debug.c/296 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.09611]
05/26/11 11:00:50.083142 zmc_dvideo7[9611].DB1-zm_monitor.cpp/1755 [Got 1 monitors]
05/26/11 11:00:50.083185 zmc_dvideo7[9611].DB2-zm_local_camera.cpp/292 [V4L support enabled, using V4L2 api]
05/26/11 11:00:50.083596 zmc_dvideo7[9611].DB1-zm_monitor.cpp/340 [monitor purpose=1]
05/26/11 11:00:50.083609 zmc_dvideo7[9611].DB1-zm_monitor.cpp/347 [mem.size=9409192]
05/26/11 11:00:50.083644 zmc_dvideo7[9611].DB1-zm_monitor.cpp/371 [Unable to map file /dev/shm/zm.mmap.21 (9409192 bytes) to locked memory, trying unlocked]
05/26/11 11:00:50.098043 zmc_dvideo7[9611].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 560x420 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
05/26/11 11:00:50.102428 zmc_dvideo7[9611].DB1-zm_monitor.cpp/460 [Monitor Monitor-21 has function 3]
05/26/11 11:00:50.102479 zmc_dvideo7[9611].DB1-zm_monitor.cpp/461 [Monitor Monitor-21 LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
05/26/11 11:00:50.102490 zmc_dvideo7[9611].DB1-zm_monitor.cpp/462 [Monitor Monitor-21 IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
05/26/11 11:00:50.112626 zmc_dvideo7[9611].DB1-zm_zone.cpp/892 [Got 1 zones for monitor Monitor-21]
05/26/11 11:00:50.112685 zmc_dvideo7[9611].DB5-zm_zone.cpp/921 [Parsing polygon 0,0 559,0 559,419 0,419]
05/26/11 11:00:50.112702 zmc_dvideo7[9611].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 559,0 559,419 0,419']
05/26/11 11:00:50.112716 zmc_dvideo7[9611].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
05/26/11 11:00:50.112725 zmc_dvideo7[9611].DB3-zm_zone.cpp/796 [Got coordinate 559,0 from polygon string]
05/26/11 11:00:50.112735 zmc_dvideo7[9611].DB3-zm_zone.cpp/796 [Got coordinate 559,419 from polygon string]
05/26/11 11:00:50.112744 zmc_dvideo7[9611].DB3-zm_zone.cpp/796 [Got coordinate 0,419 from polygon string]
05/26/11 11:00:50.112758 zmc_dvideo7[9611].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
05/26/11 11:00:50.112769 zmc_dvideo7[9611].DB1-zm_zone.cpp/50 [Initialised zone 21/All - 1 - 560x420 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:7056, MxAP:176400, FB:3x3, MnFP:7056, MxFP:176400, MnBS:4704, MxBS:0, MnB:1, MxB:0, OF: 0]
05/26/11 11:00:50.117280 zmc_dvideo7[9611].DB1-zm_monitor.cpp/1857 [Loaded monitor 21(Monitor-21), 1 zones]
05/26/11 11:00:50.117296 zmc_dvideo7[9611].INF-zmc.cpp/191 [Starting Capture]
05/26/11 11:00:50.122036 zmc_dvideo7[9611].FAT-zm_local_camera.cpp/349 [Failed to stat video device /dev/video7: No such file or directory]
tibetfreedom
Does anyone have anything on this ?
Please…
further logs I think this has the answer….
05/26/11 13:19:17.081934 zmc_dvideo7[10160].INF-zm_debug.c/296 [New Debug Level = 9, New Debug Log = /tmp/zm_debug.log.10160]
05/26/11 13:19:17.082202 zmc_dvideo7[10160].DB1-zm_monitor.cpp/1755 [Got 1 monitors]
05/26/11 13:19:17.082248 zmc_dvideo7[10160].DB2-zm_local_camera.cpp/292 [V4L support enabled, using V4L2 api]
05/26/11 13:19:17.082642 zmc_dvideo7[10160].DB1-zm_monitor.cpp/340 [monitor purpose=1]
05/26/11 13:19:17.082653 zmc_dvideo7[10160].DB1-zm_monitor.cpp/347 [mem.size=9409192]
05/26/11 13:19:17.082684 zmc_dvideo7[10160].DB1-zm_monitor.cpp/371 [Unable to map file /dev/shm/zm.mmap.21 (9409192 bytes) to locked memory, trying unlocked]
05/26/11 13:19:17.090300 zmc_dvideo7[10160].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 560x420 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
05/26/11 13:19:17.090609 zmc_dvideo7[10160].DB9-zm_image.cpp/1352 [x1:0,y1:419 x2:0,y2:0]
05/26/11 13:19:17.090623 zmc_dvideo7[10160].DB9-zm_image.cpp/1352 [x1:0,y1:0 x2:559,y2:0]
05/26/11 13:19:17.090632 zmc_dvideo7[10160].DB9-zm_image.cpp/1352 [x1:559,y1:0 x2:559,y2:419]
05/26/11 13:19:17.090641 zmc_dvideo7[10160].DB9-zm_image.cpp/1352 [x1:559,y1:419 x2:0,y2:419]
05/26/11 13:19:17.090658 zmc_dvideo7[10160].DB9-zm_image.cpp/1372 [0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090684 zmc_dvideo7[10160].DB9-zm_image.cpp/1372 [1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090700 zmc_dvideo7[10160].DB9-zm_image.cpp/1386 [Moving global edge]
05/26/11 13:19:17.090714 zmc_dvideo7[10160].DB9-zm_image.cpp/1386 [Moving global edge]
05/26/11 13:19:17.090723 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [0 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090733 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [0 - 1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090748 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [1 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090758 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [1 - 1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090773 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [2 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090782 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [2 - 1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090797 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [3 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090807 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [3 - 1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090821 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [4 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090831 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [4 - 1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090845 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [5 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090855 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [5 - 1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090869 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [6 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
05/26/11 13:19:17.090879 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [6 - 1: min_y: 0, max_y:419, min_x:559.00, 1/m:0.00]
05/26/11 13:19:17.090893 zmc_dvideo7[10160].DB9-zm_image.cpp/1407 [7 - 0: min_y: 0, max_y:419, min_x:0.00, 1/m:-0.00]
etc…….
about 5,000 lines of bedbug…
then…
05/26/11 13:19:17.150863 zmc_dvideo7[10160].DB9-zm_image.cpp/1314 [x:5, y:419.00]
05/26/11 13:19:17.150871 zmc_dvideo7[10160].DB9-zm_image.cpp/1314 [x:4, y:419.00]
05/26/11 13:19:17.150880 zmc_dvideo7[10160].DB9-zm_image.cpp/1314 [x:3, y:419.00]
05/26/11 13:19:17.150889 zmc_dvideo7[10160].DB9-zm_image.cpp/1314 [x:2, y:419.00]
05/26/11 13:19:17.150897 zmc_dvideo7[10160].DB9-zm_image.cpp/1314 [x:1, y:419.00]
05/26/11 13:19:17.153263 zmc_dvideo7[10160].DB1-zm_monitor.cpp/1857 [Loaded monitor 21(Monitor-21), 1 zones]
05/26/11 13:19:17.153276 zmc_dvideo7[10160].INF-zmc.cpp/191 [Starting Capture]
05/26/11 13:19:17.153442 zmc_dvideo7[10160].FAT-zm_local_camera.cpp/349 [Failed to stat video device /dev/video7: No such file or directory]
mastertheknife
Post by mastertheknife »
Please post complete output of: dmesg | grep bttv
mastertheknife
Kfir Itzhak.
tibetfreedom
mastertheknife wrote:Hi,
mastertheknife
Thanks…
root@CCTV:/tmp# dmesg | grep bttv
That's it...
tibetfreedom
Also…
No video devices showing although the driver appears to have loaded…
root@CCTV:/dev# ls
agpgart  cpu_dma_latency  fuse	   loop0    mcelog		ptmx	sda1	  sr0	  tty12  tty20	tty29  tty37  tty45  tty53  tty61  ttyS3    vcs6   vcsa7
block	 disk		  fw0	   loop1    mem			pts	sda2	  stderr  tty13  tty21	tty3   tty38  tty46  tty54  tty62  urandom  vcs7   vga_arbiter
bsg	 dri		  hidraw0  loop2    net			random	sda5	  stdin   tty14  tty22	tty30  tty39  tty47  tty55  tty63  usb	    vcsa   xconsole
bus	 dvd		  hidraw1  loop3    network_latency	rfkill	sg0	  stdout  tty15  tty23	tty31  tty4   tty48  tty56  tty7   vcs	    vcsa1  zero
cdrom	 dvdrw		  hpet	   loop4    network_throughput	root	sg1	  tty	  tty16  tty24	tty32  tty40  tty49  tty57  tty8   vcs1     vcsa2
cdrw	 fb0		  initctl  loop5    null		rtc	shm	  tty0	  tty17  tty25	tty33  tty41  tty5   tty58  tty9   vcs2     vcsa3
char	 fd		  input    loop6    port		rtc0	snapshot  tty1	  tty18  tty26	tty34  tty42  tty50  tty59  ttyS0  vcs3     vcsa4
console  fd0		  kmsg	   loop7    ppp			scd0	snd	  tty10   tty19  tty27	tty35  tty43  tty51  tty6   ttyS1  vcs4     vcsa5
core	 full		  log	   MAKEDEV  psaux		sda	sndstat   tty11   tty2	 tty28	tty36  tty44  tty52  tty60  ttyS2  vcs5     vcsa6
tibetfreedom
mastertheknife
Are there any clues here ?
mastertheknife
Do you have pictures of the card?
mastertheknife
Kfir Itzhak.
tibetfreedom
mastertheknife wrote:Do you have pictures of the card?
mastertheknife
It's a camsecure clone bt878 8 chip 8 port
looks just like this…
http://www.zoneminder.com/wiki/index.php/File:Karta.jpg
mastertheknife
Same card as mine.
What options do you use in bttv.conf?
Kfir Itzhak.
