[Solved] How to see more than one camera at the same time?
gamba47
Post by gamba47 » Sun Mar 20, 2011 8:05 pm
Hello to all!
I´m using at this moment geovision cards (most of all are gv-800)
After a lot of time reading the forum i did not find any solution for my question.
I install my ZM 1.24.2 on Ubuntu Maverick and works OK. Using aptitude.
I need to know if its possible to get a web with screen division like program "DmMultiview" from Geovision.
I can´t post images from internet to show you what i want to do.
There is any solution for this ? the thing is i need to se more than one camera at the same time.
Can i create a web with links to some monitors ?
Best regards.
gamba47
bb99
Re: How to do something like Geovision?
Post by bb99 » Sun Mar 20, 2011 8:32 pm
Montage isn't what you're looking for?
gamba47
Post by gamba47 » Sun Mar 20, 2011 9:22 pm
bb99 wrote:Montage isn't what you're looking for?
Yes!! thanks for your quick anwser!!!
Link for the solution http://www.zoneminder.com/wiki/index.ph ... le_cameras
I will try this.
Best regards.
gamba47
