Page 1 of 1
Zones confing
Posted: Sun Jan 30, 2011 5:25 pm
by insippo
What is the optimal zone conf? My sample is here
How to conf alarm video length?
What is Alarm Color ?
Posted: Wed Feb 02, 2011 4:21 am
by whatboy
Length can be changed by tweaking the buffer tab on the monitor options...
Depends on FPS and how many seconds you want to record before and after an alarm is triggered!!!
If 5 fps and want to record 20 seconds... you can put like...
Pre Event Image Count 50
Post Event Image Count 50
Alarm color is for when the "analysed alarm images" option is set, it will high light the alarm zones which triggered (redundant saying) the alarm...
Posted: Wed Feb 02, 2011 9:51 am
by insippo
I put
Yesterday, the snow caused 800 alerts.
This is not the best picture but still... There are hundreds(thousends,billions) of such pictures
how to fix this?
Posted: Wed Feb 02, 2011 5:01 pm
by whatboy
Length is one thing sensibility is another... use a pre-set and start from there... but it is very difficult to fine tune the sensibility... I have a problem with cloud shadows... they suck!!!
Posted: Wed Feb 02, 2011 5:12 pm
by insippo
clouds is a problem nr.2. At the moment is snow after 2 months is rain and clouds problem nr.1
I put monitor->buffer->alarm frame count 2 and alarms from snow ended.Today.Sky is clear.
