Hello
When i try to use scalling in montage view
with SVN ZM 1.24.3 updated today
nothing change
i use: override detection streaming browser to "NO"
Method should be used "JPEG"
I use Cambozzola
and Firefox
Scalling in montage view - Have a bug with ZM 1.24.3 SVN
I've been having issues with the montage scaling since several minor release back. It's always been an issue with the mootools libs. Firebug is good for locating these problems.
They've alway been where mootools assume a parameter is defined and try's to call a member varaible from the pramater. In 1.24.3's latest SVN version, it's (in a expanded view):
The parameter b is undefined. When running the montage view and causes a java script error (which kills the rest of the javascript on that page). It's pretty bad practice to blindly trust input parameters like that.
I've never had a chance to drill down into mootools and see why b is undefined, so I just make the function exit when b is undefined.
Here is a patch of my change off of ZM SVN:
This patches the mootool file Zoneminders source folder, you can apply that patch to your source folder and do a "make install".
function(a,b)
if(b._groupSend)
return this;
Index: web/tools/mootools/mootools-1.2.5.1-more-yc.js
--- web/tools/mootools/mootools-1.2.5.1-more-yc.js (revision 3224)
+++ web/tools/mootools/mootools-1.2.5.1-more-yc.js (working copy)
@@ -479,7 +479,7 @@
}});Request.JSONP.counter=0;Request.JSONP.request_map={};Request.Queue=new Class({Implements:[Options,Events],Binds:["attach","request","complete","cancel","success","failure","exception"],options:{stopOnFailure:true,autoAdvance:true,concurrent:1,requests:{}},initialize:function(a){if(a){var b=a.requests;
delete a.requests;}this.setOptions(a);this.requests=new Hash;this.queue=[];this.reqBinders={};if(b){this.addRequests(b);}},addRequest:function(a,b){this.requests.set(a,b);
this.attach(a,b);return this;},addRequests:function(a){$each(a,function(c,b){this.addRequest(b,c);},this);return this;},getName:function(a){return this.requests.keyOf(a);
-},attach:function(a,b){if(b._groupSend){return this;}["request","complete","cancel","success","failure","exception"].each(function(c){if(!this.reqBinders[a]){this.reqBinders[a]={};
+},attach:function(a,b){if(b == undefined){return;}if(b._groupSend){return this;}["request","complete","cancel","success","failure","exception"].each(function(c){if(!this.reqBinders[a]){this.reqBinders[a]={};
}this.reqBinders[a][c]=function(){this["on"+c.capitalize()].apply(this,[a,b].extend(arguments));}.bind(this);b.addEvent(c,this.reqBinders[a][c]);},this);
b._groupSend=b.send;b.send=function(c){this.send(a,c);return b;}.bind(this);return this;},removeRequest:function(b){var a=$type(b)=="object"?this.getName(b):b;
if(!a&&$type(a)!="string"){return this;}b=this.requests.get(a);if(!b){return this;}["request","complete","cancel","success","failure","exception"].each(function(c){b.removeEvent(c,this.reqBinders[a][c]);
i copied your source to a diff file and executed the following command:
patch mootools-1.2.5.1-more-yc.js < patch.diff
The command outputs the following:
this is the rejects file:
I have no expercience doing patches, so i'm guessing i'm doing something wrong...
patching file mootools-1.2.5.1-more-yc.js
patch unexpectedly ends in middle of line
Hunk #1 FAILED at 479.
1 out of 1 hunk FAILED -- saving rejects to file mootools-1.2.5.1-more-yc.js.rej
Index: mootools-1.2.5.1-more-yc.js
--- mootools-1.2.5.1-more-yc.js (revision 3224)
+++ mootools-1.2.5.1-more-yc.js (working copy)
@@ -479,7 +479,7 @@
Users browsing this forum: No registered users and 5 guests
