Scalling in montage view - Have a bug with ZM 1.24.3 SVN
christophe_y2k
Post by christophe_y2k » Sun Jan 02, 2011 7:50 pm
Hello
When i try to use scalling in montage view
with SVN ZM 1.24.3 updated today
nothing change
i use: override detection streaming browser to "NO"
Method should be used "JPEG"
I use Cambozzola
and Firefox
midian
Post by midian » Tue Jan 11, 2011 4:19 am
There are a few posts about this, but I believe the consensus is that Montage scaling does not work in Firefox, but may in other browsers. I admit it seems a bit strange that an open source product would favor M$.
timcraig
Post by timcraig » Sat Jan 15, 2011 8:36 pm
I've been having issues with the montage scaling since several minor release back. It's always been an issue with the mootools libs. Firebug is good for locating these problems.
They've alway been where mootools assume a parameter is defined and try's to call a member varaible from the pramater. In 1.24.3's latest SVN version, it's (in a expanded view):
function(a,b)
  if(b._groupSend)
    return this;
The parameter b is undefined. When running the montage view and causes a java script error (which kills the rest of the javascript on that page). It's pretty bad practice to blindly trust input parameters like that.
I've never had a chance to drill down into mootools and see why b is undefined, so I just make the function exit when b is undefined.
Here is a patch of my change off of ZM SVN:
Index: web/tools/mootools/mootools-1.2.5.1-more-yc.js
--- web/tools/mootools/mootools-1.2.5.1-more-yc.js	(revision 3224)
+++ web/tools/mootools/mootools-1.2.5.1-more-yc.js	(working copy)
@@ -479,7 +479,7 @@
 }});Request.JSONP.counter=0;Request.JSONP.request_map={};Request.Queue=new Class({Implements:[Options,Events],Binds:["attach","request","complete","cancel","success","failure","exception"],options:{stopOnFailure:true,autoAdvance:true,concurrent:1,requests:{}},initialize:function(a){if(a){var b=a.requests;
 delete a.requests;}this.setOptions(a);this.requests=new Hash;this.queue=[];this.reqBinders={};if(b){this.addRequests(b);}},addRequest:function(a,b){this.requests.set(a,b);
 this.attach(a,b);return this;},addRequests:function(a){$each(a,function(c,b){this.addRequest(b,c);},this);return this;},getName:function(a){return this.requests.keyOf(a);
-},attach:function(a,b){if(b._groupSend){return this;}["request","complete","cancel","success","failure","exception"].each(function(c){if(!this.reqBinders[a]){this.reqBinders[a]={};
+},attach:function(a,b){if(b == undefined){return;}if(b._groupSend){return this;}["request","complete","cancel","success","failure","exception"].each(function(c){if(!this.reqBinders[a]){this.reqBinders[a]={};
 }this.reqBinders[a][c]=function(){this["on"+c.capitalize()].apply(this,[a,b].extend(arguments));}.bind(this);b.addEvent(c,this.reqBinders[a][c]);},this);
 b._groupSend=b.send;b.send=function(c){this.send(a,c);return b;}.bind(this);return this;},removeRequest:function(b){var a=$type(b)=="object"?this.getName(b):b;
 if(!a&&$type(a)!="string"){return this;}b=this.requests.get(a);if(!b){return this;}["request","complete","cancel","success","failure","exception"].each(function(c){b.removeEvent(c,this.reqBinders[a][c]);
This patches the mootool file Zoneminders source folder, you can apply that patch to your source folder and do a "make install".
beire
Post by beire » Sun Jan 16, 2011 12:23 pm
i copied your source to a diff file and executed the following command:
patch mootools-1.2.5.1-more-yc.js < patch.diff
The command outputs the following:
patching file mootools-1.2.5.1-more-yc.js
patch unexpectedly ends in middle of line
Hunk #1 FAILED at 479.
1 out of 1 hunk FAILED -- saving rejects to file mootools-1.2.5.1-more-yc.js.rej
this is the rejects file:
Index: mootools-1.2.5.1-more-yc.js
--- mootools-1.2.5.1-more-yc.js (revision 3224)
+++ mootools-1.2.5.1-more-yc.js (working copy)
@@ -479,7 +479,7 @@
I have no expercience doing patches, so i'm guessing i'm doing something wrong...
timcraig
Post by timcraig » Mon Jan 17, 2011 2:50 am
Beire, try moving the patch.diff to your Zoneminder source folder. Then open a terminal and change the directory to you Zoneminder source folder and run the command:
patch -p0 -i patch.diff
Users browsing this forum: No registered users and 12 guests
