Zoneminder development
I have found this :
http://blog.cvisionlab.com/2010/10/vide ... .html#more
Is anyone of this forum using this plugins?. Are they going to be added in a next ZM version or are they a parallel development?
Regards,
PacoLM
I have found this :
Regards,
PacoLM
We are going to release sources of our Zoneminder fork on bitbucket soon. We also will be happy if Zoneminder's team accept our patches.
Re: parallel development
Likewise, i have made some patches to fix some web interface issues and other general issues and interested in sending them to the ZoneMinder's team but not sure to who and how. I wish ZoneMinder would be hosted on github, this would make forking and patching a lot nicer and easier.gorban wrote:We also will be happy if Zoneminder's team accept our patches.
Right now i am using git-svn to checkout ZM's SVN and then i am rebasing it against my local repository which contains some patches.
I'm looking into setting it up on GitHub, but am checking with Phil first... stay tuned.
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
ZoneMinder fork
R&D in Computer vision
Re: ZoneMinder fork
I'm very excited about your additions, but I'm having trouble compiling them. Configure succeeded, but make is stuck on the following error:
$ make
make all-recursive
make[1]: Entering directory `/home/peter/zm-gorban/zoneminder'
Making all in src
make[2]: Entering directory `/home/peter/zm-gorban/zoneminder/src'
g++ -frepo -g -O2 -L/usr/lib -L/usr/lib/mysql -rdynamic -o zmc zmc.o zm_box.o zm_buffer.o zm_camera.o zm_comms.o zm_config.o zm_coord.o zm.o zm_db.o zm_debug.o zm_event.o zm_exception.o zm_file_camera.o zm_ffmpeg_camera.o zm_image.o zm_jpeg.o zm_local_camera.o zm_monitor.o zm_ffmpeg.o zm_mpeg.o zm_poly.o zm_regexp.o zm_remote_camera.o zm_remote_camera_http.o zm_remote_camera_rtsp.o zm_rtp.o zm_rtp_ctrl.o zm_rtp_data.o zm_rtp_source.o zm_rtsp.o zm_sdp.o zm_signal.o zm_stream.o zm_thread.o zm_time.o zm_timer.o zm_user.o zm_utils.o zm_zone.o -lz -lpcre -lgnutls-openssl -ldl -lpthread -ljpeg -lmysqlclient
zm_monitor.o: In function `Monitor::Analyse()':
/home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:1291: undefined reference to `ImageAnalyser::DoDetection(Image const&, Zone**, int, std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&)'
zm_monitor.o: In function `Monitor':
/home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:325: undefined reference to `PluginManager::PluginManager()'
/home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:476: undefined reference to `join_paths(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:478: undefined reference to `PluginManager::loadPlugin(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:487: undefined reference to `PluginManager::configurePlugins(std::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
zm_monitor.o: In function `PluginManager::setPluginExt(std::basic_string<char, std::char_traits<char>, std::allocator<char> >)':
/home/peter/zm-gorban/zoneminder/src/zm_plugin_manager.h:69: undefined reference to `PluginManager::m_sPluginExt'
zm_monitor.o: In function `~pair':
/usr/include/c++/4.4/bits/stl_pair.h:68: undefined reference to `Plugin::~Plugin()'
zm_monitor.o: In function `~PluginManager':
/home/peter/zm-gorban/zoneminder/src/zm_plugin_manager.h:49: undefined reference to `ImageAnalyser::~ImageAnalyser()'
collect2: ld returned 1 exit status
make[2]: *** [zmc] Error 1
make[2]: Leaving directory `/home/peter/zm-gorban/zoneminder/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/peter/zm-gorban/zoneminder'
make: *** [all] Error 2
I tried using automake to regenerate the Makefiles, but zoneminder seems to have some different method, perhaps through scripts/ZoneMinder/Makefile.PL ? I'm not familiar enough with this build structure to see exactly where the problem is. If I haven't figured it out soon, I'll probably try to directly edit the src/Makefile to include the changes from Makefile.am.
An example of plugin (face detector) is added to the bitbucket repo to the `plugins' directory. To the Wiki we have added information about building.
Please visit our http://blog.cvisionlab.com/ blog and post you comments there too.
Re: ZoneMinder fork
Have the same error. How is autoconfig supposed to help ? Tried that, but didn't progress.laxpeter wrote:I'm very excited about your additions, but I'm having trouble compiling them. Configure succeeded, but make is stuck on the following error:
From what I can tell, this is because the Makefile in src/ does not contain the new source files in am__objects_1, zm_SOURCES, or noinst_HEADERS. I see the additional files (zm_plugin_manager.cpp, etc) in src/Makefile.am but not src/Makefile.in.Code: Select all
$ make make all-recursive make[1]: Entering directory `/home/peter/zm-gorban/zoneminder' Making all in src make[2]: Entering directory `/home/peter/zm-gorban/zoneminder/src' g++ -frepo -g -O2 -L/usr/lib -L/usr/lib/mysql -rdynamic -o zmc zmc.o zm_box.o zm_buffer.o zm_camera.o zm_comms.o zm_config.o zm_coord.o zm.o zm_db.o zm_debug.o zm_event.o zm_exception.o zm_file_camera.o zm_ffmpeg_camera.o zm_image.o zm_jpeg.o zm_local_camera.o zm_monitor.o zm_ffmpeg.o zm_mpeg.o zm_poly.o zm_regexp.o zm_remote_camera.o zm_remote_camera_http.o zm_remote_camera_rtsp.o zm_rtp.o zm_rtp_ctrl.o zm_rtp_data.o zm_rtp_source.o zm_rtsp.o zm_sdp.o zm_signal.o zm_stream.o zm_thread.o zm_time.o zm_timer.o zm_user.o zm_utils.o zm_zone.o -lz -lpcre -lgnutls-openssl -ldl -lpthread -ljpeg -lmysqlclient zm_monitor.o: In function `Monitor::Analyse()': /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:1291: undefined reference to `ImageAnalyser::DoDetection(Image const&, Zone**, int, std::map<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::set<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >, std::basic_string<char, std::char_traits<char>, std::allocator<char> >&)' zm_monitor.o: In function `Monitor': /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:325: undefined reference to `PluginManager::PluginManager()' /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:476: undefined reference to `join_paths(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:478: undefined reference to `PluginManager::loadPlugin(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:487: undefined reference to `PluginManager::configurePlugins(std::basic_string<char, std::char_traits<char>, std::allocator<char> >)' /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:325: undefined reference to `PluginManager::PluginManager()' /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:476: undefined reference to `join_paths(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:478: undefined reference to `PluginManager::loadPlugin(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)' /home/peter/zm-gorban/zoneminder/src/zm_monitor.cpp:487: undefined reference to `PluginManager::configurePlugins(std::basic_string<char, std::char_traits<char>, std::allocator<char> >)' zm_monitor.o: In function `PluginManager::setPluginExt(std::basic_string<char, std::char_traits<char>, std::allocator<char> >)': /home/peter/zm-gorban/zoneminder/src/zm_plugin_manager.h:69: undefined reference to `PluginManager::m_sPluginExt' zm_monitor.o: In function `~pair': /usr/include/c++/4.4/bits/stl_pair.h:68: undefined reference to `Plugin::~Plugin()' zm_monitor.o: In function `~PluginManager': /home/peter/zm-gorban/zoneminder/src/zm_plugin_manager.h:49: undefined reference to `ImageAnalyser::~ImageAnalyser()' collect2: ld returned 1 exit status make[2]: *** [zmc] Error 1 make[2]: Leaving directory `/home/peter/zm-gorban/zoneminder/src' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/peter/zm-gorban/zoneminder' make: *** [all] Error 2
Re: ZoneMinder fork
I had that error when trying to follow the instructions in the INSTALL file included with the source.bdmcnxn wrote:Have the same error. How is autoconfig supposed to help ? Tried that, but didn't progress.
Rather than make, and make install, I should have been using the:
aclocal
autoconf
automake
make
https://bitbucket.org/gorban/zoneminder/wiki/building
wiki source instructions
Re: ZoneMinder fork
Thanks a lot laxpeter. That worked.laxpeter wrote:I had that error when trying to follow the instructions in the INSTALL file included with the source.bdmcnxn wrote:Have the same error. How is autoconfig supposed to help ? Tried that, but didn't progress.
Rather than make, and make install, I should have been using the:procedure from the wiki and the plugin fork's website:Code: Select all
aclocal autoconf automake make
Users browsing this forum: No registered users and 6 guests
