having trouble with zoneminder 1.24.2 on ubuntu 10.04 server
dmb2002man
Post by dmb2002man » Mon Nov 15, 2010 12:11 pm
Alan87i wrote:$ sudo adduser www-data video (did you do this ?)
Check if www-data is in the video group. cat /etc/group | more
already have added the user. see my results here.
video:x:44:www-data
root@ubuntu-test:~# sudo adduser www-data video
The user `www-data' is already a member of `video'.
root@ubuntu-test:~#
i also did a chmod 777 /dev/video0 and chmod 777 /dev/video1, so it cant be a permission issue. I need to finish this project for work and get the cameras to record and i need this up soon. Is there an alternative to zoneminder that is also freeware. Any programs for a windows xp box too.
also found this post with no solution.
http://www.zoneminder.com/forums/viewto ... 9628a17f72
Yamanipanuchi
Post by Yamanipanuchi » Mon Nov 15, 2010 2:32 pm
I upgraded to Ubuntu 10.10 this weekend and install Zoneminder from apt-get and im now having this same problem.
Its a shared memory problem.
I've increased the shared memory values in /etc/sysctl.conf
I've also verified that www-data is in the video group several times.
I seem to remember having this issues with a fedora install I did sometime back, The answer was hidden in a post almost completely unrelated. But I just cant find it.
Yamanipanuchi
Post by Yamanipanuchi » Mon Nov 15, 2010 6:49 pm
So I got my setup working finally.
Took some goofing off, but here's what I did.
I edited /etc/zm/zm.conf
Changed Zoneminder to run as root and group as root. Then I ran...
sudo chown root.root -R /var/cache/zoneminder/events
This didn't fix the problem so I reversed the process to set it back to what was default.
Edited /etc/zm/zm.conf
Changed Zoneminder to run as www-data and group as www-data. Then I ran...
sudo chown www-data.www-data -R /var/cache/zoneminder/events
After then it worked! Unfortunately I don't know exactly why or how, But I have all greens and everything working perfectly!
I suspect that I only needed to run 'sudo chown www-data.www-data -R /var/cache/zoneminder/events' and it probably would have fixed the problem.
Please let me know if this works for you?
scarrz
Post by scarrz » Tue Nov 16, 2010 2:04 pm
Tried this but still doesn't work. I had a nice zoneminder 1.23 setup on Ubuntu 8.x but decided to upgrade, (that was a mistake). I feel like I'm close but cannot get video to work..
Yamanipanuchi wrote:So I got my setup working finally.
dmb2002man
Post by dmb2002man » Tue Nov 23, 2010 7:09 pm
i ran this command and still zoneminder shows red for me.
root@camera-pc:~# tail /var/log/messages
Nov 23 01:23:30 camera-pc zmdc[5666]: INF [Starting pending process, zmc -d /dev/video1]
Nov 23 01:23:30 camera-pc zmdc[5705]: INF ['zmc -d /dev/video1' started at 10/11/23 01:23:30]
Nov 23 01:23:30 camera-pc zmdc[5666]: INF ['zmc -d /dev/video1' starting at 10/11/23 01:23:30, pid = 5705]
Nov 23 01:23:30 camera-pc zmc_dvideo1[5705]: INF [Debug Level = 0, Debug Log = <none>]
Nov 23 01:23:30 camera-pc zmc_dvideo1[5705]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.05705]
Nov 23 01:23:31 camera-pc zmdc[5666]: INF [Starting pending process, zmc -d /dev/video0]
Nov 23 01:23:31 camera-pc zmdc[5706]: INF ['zmc -d /dev/video0' started at 10/11/23 01:23:31]
Nov 23 01:23:31 camera-pc zmdc[5666]: INF ['zmc -d /dev/video0' starting at 10/11/23 01:23:31, pid = 5706]
Nov 23 01:23:31 camera-pc zmc_dvideo0[5706]: INF [Debug Level = 0, Debug Log = <none>]
Nov 23 01:23:31 camera-pc zmc_dvideo0[5706]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.05706]
root@camera-pc:~# tail /tmp/zm_debug.log.05706
11/23/10 01:23:31.117387 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/92 [Old D:0]
11/23/10 01:23:31.117405 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/93 [Old B:32896]
11/23/10 01:23:31.117422 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/94 [Old h:32896]
11/23/10 01:23:31.117440 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/95 [Old Cl:33026]
11/23/10 01:23:31.117457 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/96 [Old Cn:33026]
11/23/10 01:23:31.120014 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/140 [Old X:0]
11/23/10 01:23:31.120032 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/141 [Old Y:0]
11/23/10 01:23:31.120049 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/142 [Old W:320]
11/23/10 01:23:31.120067 zmc_dvideo0[5706].DB1-zm_local_camera.cpp/143 [Old H:240]
11/23/10 01:23:31.120120 zmc_dvideo0[5706].ERR-zm_local_camera.cpp/162 [Failed to setup memory: Invalid argument]
root@camera-pc:~#
dmb2002man
Post by dmb2002man » Tue Nov 30, 2010 2:36 pm
dmb2002man
Post by dmb2002man » Tue Nov 30, 2010 2:37 pm
hello,
since i cannot get these cards to work, i need to find newer cards that will work. Either single pci cards or dvr pci cards. Im using 2 single cameras with bnc connectors. I also have the bnc to composite adapter. Any help would be appreciated.
thanks
theemed
Re: having trouble with zoneminder 1.24.2 on ubuntu 10.04 se
Post by theemed » Thu Mar 31, 2011 10:04 am
zoneminer 1.24.2 off standard repos on ubuntu server 10.10 x64 with minimal gnome.
I was having the "operation not permitted" error for chmod on /dev/video*, so I did what Yamanipanuchi uggested, to no avail.
But in the end I also did:
sudo chown www-data.www-data -R /dev/video*
which I reckon is brutal, but worked for me.
Now I don't know if Yamanipanuchi's line is necessary or not, I just left it.
EDIT: rebooting juust brings back the same problem, as ownership of dev/video* goes back to root, so it's not a viable solution :(
EDIT2: just added www-data to video group, works now :|
Users browsing this forum: No registered users and 18 guests
