Update: Found that patch, but can't get it to install. I don't have a base "build" directory because I didn't build from source, I installed using Synaptic package manager. Any suggestions?
Hello all,
I've been tinkering for the past few days to get ZM working with an ACTi-7411.
I unearthed a few threads with some useful information.
http://www.zoneminder.com/forums/viewtopic.php?t=12344 -- configuration of acti cameras
http://www.zoneminder.com/forums/viewto ... light=acti -- a poster named "Exno" is using the exact same camera so I know it is possible.
I've followed the directions as described, but ZoneMinder displays a 640x480 outline with the famous "Red X".
Here are my thoughts: ffmpeg works
ffmpeg -i http://eng@192.168.1.19/cgi-bin/cmd/encoder?GET_STREAM ./test.avi
This produces a legit file.
Apache error log is full of stuff, but I don't know what any of it means, so I suspect that is the problem. I keep hearing about an "ffmpeg authentication patch", but after a day of looking for it I've had no success. Maybe that would do the trick? Can someone post a link to that?
Apache2 error log:
[Sun Jun 20 14:35:32 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/options.php on line 193, referer: http://192.168.0.5/zm/index.php?view=options
[Sun Jun 20 14:35:41 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 14:35:41 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:41:00 2010] [error] [client 127.0.0.1] File does not exist: /var/www/crossdomain.xml
[Sun Jun 20 15:49:07 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:07 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:49:15 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:49:18 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:18 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:49:31 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:49:34 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:34 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:49:56 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:56 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:50:01 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:50:23 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:50:23 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:50:50 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:53:58 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:56:28 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:56:32 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:56:32 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:56:59 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:57:02 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:57:02 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:57:13 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:57:19 2010] [error] [client 192.168.0.9] socket_sendto( /tmp/zms-814575s.sock ) failed: No such file or directory, referer: http://192.168.0.5/zm/index.php?view=watch&mid=1
[Sun Jun 20 15:57:19 2010] [error] [client 192.168.0.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-814575s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.0.5/zm/index.php?view=watch&mid=1
[Sun Jun 20 16:15:00 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 16:16:17 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 16:16:17 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
sh: arp: not found
[Sun Jun 20 16:16:39 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 16:16:39 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
sh: arp: not found
[Sun Jun 20 16:26:23 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 16:27:18 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 16:31:56 2010] [notice] Graceful restart requested, doing restart
apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
[Sun Jun 20 16:31:56 2010] [notice] Apache/2.2.14 (Ubuntu) PHP/5.3.2-1ubuntu4.2 with Suhosin-Patch configured -- resuming normal operations
[Sun Jun 20 16:32:15 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:27:27 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:27:37 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:32:51 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:32:51 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 19:32:59 2010] [error] [client 192.168.1.9] File does not exist: /var/www/favicon.ico
[Sun Jun 20 19:33:03 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:33:07 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:33:07 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 19:39:13 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:39:18 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:18 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:31 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:31 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:44 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:44 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:58 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:58 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:11 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:11 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:24 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:24 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:37 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:37 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:50 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:50 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:03 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:03 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:16 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:16 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:29 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:29 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:42 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:42 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:55 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:55 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:08 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:08 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:21 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:21 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:34 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:34 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:47 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:47 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:44:15 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:44:15 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 19:44:26 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:50:13 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:50:13 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 813, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 818, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 823, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 828, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:26 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-298733s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:51:26 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-298733s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 813, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 818, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 823, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 828, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:35 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-739523s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:51:35 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-739523s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:52:37 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:53:07 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:53:10 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:53:22 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:53:22 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
sh: arp: not found
Some of the error log removed because it was too long, but these same errors kept showing up over and over again.
I hope I've included enough info on this post to be hopeful. Didn't want to be "that guy" posting "OMG help it does not work fix it!!11"
Troubles with ACTi-7411
Users browsing this forum: No registered users and 10 guests
