Cannot get mpeg4 stream from Axis camera
pignattino
Post by pignattino » Wed Mar 03, 2010 10:56 am
I'm trying to configure an Axis 211 camera to obtain a mpeg4 stream, but after saving settings of camera and platform, I can see only a black window saying "Waiting for video".
If I put the url "rtsp://192.168.52.164:554/mpeg4/1/media.amp" in a browser I can open the stream with an external application.
Can someone help me?
Francesco
antar
Re: Cannot get mpeg4 stream from Axis camera
Post by antar » Fri Mar 05, 2010 4:21 am
pignattino wrote:I'm trying to configure an Axis 211 camera to obtain a mpeg4 stream, but after saving settings of camera and platform, I can see only a black window saying "Waiting for video".
check if you have libavutils installed
and check if the CGI is enabled in apache
coke
Post by coke » Fri Mar 05, 2010 5:45 am
also, did you use the axis rtsp preset? They're lower on the list than the axis's on top. Your rtsp path looks a little off from what I'm used to. What are your settings on the source tab?
I've used the "Axis IP, mpeg4, RTP/RTSP/HTTP" on the 211's, and you just need to enter the ip address, or if it's not set for anonymous viewing, user:password@ip.address then set the resolution to 1280x1024 unless you have yours set lower.
I had at one point setup all of my axis's to use RTSP when it became available in ZM (1.24.1?), but after adding additional cameras, my CPU was starting to choke. I switched my axis's back to mjpeg, and my load went from 40 or higher to 20ish. (It's a quad core, 15's good). I'm also getting higher quality streams, without frame dropouts, weird artifacts, etc.
Has anyone else explored this issue? I was told that RTSP was faster at one point, but that seems to be drastically not the case for me. I also set the cameras to 0 compression, which dropped my load down to 15, presumably because ZM doesn't have to decompress the image.
koffu
Post by koffu » Mon Apr 19, 2010 8:20 am
Hello!
I have a similar problem, mjpeg on AXIS M1011 works prefectly, but I want mpeg4, because internet channel have not enough bandwidth. My installation - Fedora 12, logs say:
zmc_m3[5004]: FAT [You must have ffmpeg libraries installed to use remote camera protocol 'rtsp' for monitor 3]
Can somebody help me with troubleshooting?
ffmpeg with ffmpeg-libs are installed from rpmfusion repos.
koffu
Post by koffu » Tue Apr 20, 2010 4:47 pm
One day of hark work to make zoneminder to solve
give nothing. Manual depends handling move out warnings from configure stage, but still get the same error with debian and fedora servers...
Can somebody help with this issue????
koffu
Post by koffu » Wed Apr 21, 2010 3:50 pm
I have in config.status
D["HAVE_LIBAVFORMAT_AVFORMAT_H"]=" 1"
how to enable also
D["HAVE_LIBAVFORMAT"]=" 1"
novazion
Post by novazion » Fri Apr 23, 2010 4:16 pm
I found something interesting, but I'm don't have enough Linux skills to clearly understand this solution:
The discussion comes from a fedora list:
http://www.mail-archive.com/users@lists ... 07752.html
koffu
Post by koffu » Fri Apr 23, 2010 10:04 pm
Thank you for reply, this is my topic and my answer in user mail list too, I have fixed this issue.
I recompile zoneminder with some changes to autoconfiguration script. I
'll answer, if you need more details or have some queston.
but really strange why ffmpeg-libs support was commented out in stable release??? why, if it have --with-ffmpeg option?
novazion
Post by novazion » Mon Apr 26, 2010 2:00 pm
Ok! good.
So in fact in the post you mention a patch, is this only for configure.ac?
Can you provide it?
Thanls!
Users browsing this forum: No registered users and 11 guests
