4 Cam, 4 hard drives how modify function getDiskPercent ?
Flav
Post by Flav » Mon Mar 01, 2010 12:11 pm
Hi.
Y need modify the function iin nclude/fonction.php
function getDiskPercent()
    $df = shell_exec( 'df '.ZM_DIR_EVENTS );
    $space = -1;
    if ( preg_match( '/\s(\d+)%/ms', $df, $matches ) )
        $space = $matches[1];
    return( $space );
I have 4 Hard drives mounting like this
sdc1 --> /usr/share/zoneminder/events/1
sdd1 --> /usr/share/zoneminder/events/2
sde1 --> /usr/share/zoneminder/events/3
sdf1 --> /usr/share/zoneminder/events/4
I want creat filter with the diskspace function but this one give me the space in /usr/share/zoneminder/events the first HD sda1
And i'm not and good dev can someone help me ?
thanks
coke
Post by coke » Mon Mar 01, 2010 2:04 pm
Is there a good reason to have them all on separate disks? Have you considered LVM? It's great for attaching sets of disks, and when you decide to add more later it's just a few simple commands.
Flav
Post by Flav » Mon Mar 01, 2010 5:30 pm
coke wrote:Is there a good reason to have them all on separate disks? Have you considered LVM? It's great for attaching sets of disks, and when you decide to add more later it's just a few simple commands.
I dont take the good explain.
It's for a private parking My system is a ubuntu with scsi Disksbay
All cam are hight def and they ars in Record Mode
We must save 3 month of records
The disksbay is attached like this (and i can't change it)
3 x 1Tb RAID 5 --> SDC1 --> Monitor1
3 x 1Tb RAID 5 --> SDD1 --> Monitor2
3 x 1Tb RAID 5 --> SDE1 --> Monitor3
3 x 1Tb RAID 5 --> SDF1 --> Monitor4
coke
Post by coke » Mon Mar 01, 2010 9:25 pm
LVM is a method of pooling the disks to appear as 1. If you could reformat/arrange the volumes into an LVM then your 4 1 terabyte raids would show up as one big 16 terabyte disk.
Warning: LVM is not for the faint of heart, or for the boot partition. Google LVM2 in your native language and see if it's something you could do/would want to do.
coke
Post by coke » Mon Mar 01, 2010 9:33 pm
Meanwhile, my regex is too rusty to argue with the other lines, but you'll want to change line 3 to
$df = shell_exec( 'df --total /usr/share/zoneminder/events/1 /usr/share/zoneminder/events/2 /usr/share/zoneminder/events/3 /usr/share/zoneminder/events/4' );
It's a start.
Flav
Post by Flav » Mon Mar 01, 2010 10:16 pm
coke wrote:LVM is a method of pooling the disks to appear as 1. If you could reformat/arrange the volumes into an LVM then your 4 1 terabyte raids would show up as one big 16 terabyte disk.
I know But the System Administrator don't want change to LVM
Users browsing this forum: No registered users and 16 guests
