no stills
NokSuKao
no stills
Post by NokSuKao »
Hi
i'm using ZoneMinder 1.24.2 with opensuse 11.1 32 bit. everything works fine, but i can't see the stills. On a system with opensuse 10.3 and ZM 1.24.1 the stills work. Where is the problem? are there any libraries missing?
ths for help
NokSuKao
cordel
Post by cordel »
With a guess I'd say that there is a path or permission issue, what do the logs say for apache?
dasbooter
Post by dasbooter »
similiar problem with ubuntu 9.10 everything working but stills. I thought it was strange that using a guest xp os and internet explorer allowed me to get the stills whereas firefox failed to do so. Maybe that is a hint. I have looked at the apache logs the error log is:
[Sun Dec 20 22:41:21 2009] [error] [client 192.168.0.101] socket_sendto( /tmp/zms-829515s.sock ) failed: No such file or directory, referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:41:21 2009] [error] [client 192.168.0.101] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-829515s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:41:28 2009] [error] [client 192.168.0.101] socket_sendto( /tmp/zms-829515s.sock ) failed: No such file or directory, referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:41:28 2009] [error] [client 192.168.0.101] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-829515s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:44:44 2009] [error] [client 192.168.0.101] socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory, referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:44:44 2009] [error] [client 192.168.0.101] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:44:51 2009] [error] [client 192.168.0.101] socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory, referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:44:51 2009] [error] [client 192.168.0.101] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1
[Sun Dec 20 22:45:06 2009] [error] [client 192.168.0.101] socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory, referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#
[Sun Dec 20 22:45:06 2009] [error] [client 192.168.0.101] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#
[Sun Dec 20 22:45:12 2009] [error] [client 192.168.0.101] socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory, referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#
[Sun Dec 20 22:45:12 2009] [error] [client 192.168.0.101] array (\n  0 => \n  array (\n    'file' => '/usr/share/zoneminder/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /tmp/zms-032893s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/usr/share/zoneminder/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/usr/share/zoneminder/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#
[Sun Dec 20 22:46:27 2009] [error] [client 192.168.0.101] File does not exist: /usr/share/zoneminder/favicon.ico
access log snippet:
(compatible; MSIE 6.0; Windows NT 5.1; SV1)"
192.168.0.101 - - [20/Dec/2009:22:45:13 -0600] "POST /index.php HTTP/1.1" 200 641 "http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
192.168.0.101 - - [20/Dec/2009:22:45:14 -0600] "POST /index.php HTTP/1.1" 200 639 "http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
192.168.0.101 - - [20/Dec/2009:22:45:14 -0600] "POST /index.php HTTP/1.1" 200 640 "http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
192.168.0.101 - - [20/Dec/2009:22:45:14 -0600] "POST /index.php HTTP/1.1" 200 0 "http://192.168.0.100/?view=event&eid=4&sort_field=StartTime&sort_asc=1&page=1#" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
192.168.0.101 - - [20/Dec/2009:22:46:10 -0600] "GET / HTTP/1.1" 200 2421 "-" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:46:14 -0600] "GET /tools/mootools/mootools-1.2.1-core-nc.js HTTP/1.1" 200 26491 "http://192.168.0.100/" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:46:14 -0600] "GET /tools/mootools/mootools-1.2-more-nc.js HTTP/1.1" 200 10777 "http://192.168.0.100/" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:46:23 -0600] "GET /?view=events&page=1 HTTP/1.1" 200 2171 "http://192.168.0.100/" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:46:27 -0600] "GET /favicon.ico HTTP/1.1" 404 504 "-" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:46:27 -0600] "GET /?view=eventdetail&eid=5 HTTP/1.1" 200 1238 "http://192.168.0.100/?view=events&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:46:33 -0600] "GET /?view=event&eid=5&sort_field=StartTime&sort_asc=1&page=1 HTTP/1.1" 200 2875 "http://192.168.0.100/?view=events&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
::1 - - [20/Dec/2009:22:46:48 -0600] "GET /index.php HTTP/1.1" 200 2325 "http://localhost/index.php" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.1.6) Gecko/20091215 Ubuntu/9.10 (karmic) Firefox/3.5.6"
192.168.0.101 - - [20/Dec/2009:22:49:58 -0600] "GET /?view=event&eid=5&sort_field=StartTime&sort_asc=1&page=1 HTTP/1.1" 200 2877 "http://192.168.0.100/?view=events&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:46:33 -0600] "GET /cgi-bin/nph-zms?source=event&mode=jpeg&event=5&frame=1&scale=100&rate=100&maxfps=15&replay=gapless&connkey=999161&rand=1261370793 HTTP/1.1" 200 58660874 "http://192.168.0.100/?view=event&eid=5&sort_field=StartTime&sort_asc=1&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:49:59 -0600] "GET /cgi-bin/nph-zms?source=event&mode=jpeg&event=5&frame=1&scale=100&rate=100&maxfps=15&replay=gapless&connkey=368933&rand=1261370998 HTTP/1.1" 200 47643440 "http://192.168.0.100/?view=event&eid=5&sort_field=StartTime&sort_asc=1&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:51:06 -0600] "GET /index.php?view=none HTTP/1.1" 200 791 "http://192.168.0.100/?view=events&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:51:15 -0600] "GET /index.php HTTP/1.1" 200 2328 "http://192.168.0.100/" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:51:24 -0600] "GET /index.php?view=events&page=1 HTTP/1.1" 200 2171 "http://192.168.0.100/index.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:51:27 -0600] "GET /index.php?view=eventdetail&eid=5 HTTP/1.1" 200 1238 "http://192.168.0.100/index.php?view=events&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
192.168.0.101 - - [20/Dec/2009:22:51:32 -0600] "GET /index.php?view=event&eid=5&sort_field=StartTime&sort_asc=1&page=1 HTTP/1.1" 200 2876 "http://192.168.0.100/index.php?view=events&page=1" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11"
::1 - - [20/Dec/2009:22:51:50 -0600] "GET /index.php HTTP/1.1" 200 2325 "http://localhost/index.php" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.1.6) Gecko/20091215 Ubuntu/9.10 (karmic) Firefox/3.5.6"
nothing in var/log/zm yet
I used debian sid packages b/c 1.24.1 caused my browser to freeze and the web page had to be restarted and compiling was fairly difficult with problems with ffmpeg.Anyways mostly working anyway
dasbooter
Post by dasbooter »
Found the problem :D .
This was a firefox cache problem. I cleared my history out this time after upgrade from 1.24.1 and everything works well .Stills come up no prob... now if I could only get the controls to work for my logitech sphere.If this fix was listed in the faq or the doc. I apologize but another post although it described a different problem clued me in :)
lots o smileys cause I'm happy
