Mapped memory
NicoArias
Mapped memory
Post by NicoArias »
Hello guys, im having some troubles with (the classic) the memory.
I upgraded from 1.23 to 1.24.2, using shared memory. After upgrade i had tons of problems with "Can't get shared memory id", after playing with the sysctrl parameters, with no luck, i decided to recompile zm with mmap, compiled, installed it, but no luck.
The weid thing is that i have nothing on /dev/shm and i keep getting Can't get shared memory id errors.
Looks like it havent compiled with mmap.
./configure --enable-mmap=YES --with-cgidir=/var/www/cgi-bin/ -with-webdir=/var/www/html/video/
any idea how i can check this?
cheers!
NicoArias
Post by NicoArias »
silly me, --enable-mmap=yes
yes!=YES
NicoArias
Post by NicoArias »
ok, now im running on mmap, but still have the "Can't get shared memory id" errors.
no images on streaming.
on the apache error logs i see:
'socket_sendto( /tmp/zms-941069s.sock ) failed: No such file or directory'
and i can confirm that that file doesnt exist
any hint will be appreciated.
zoneminder
Site Admin
Post by zoneminder »
That would normally imply that your zms isn't running. What is in the other logs?
Phil
johnnytolengo
Post by johnnytolengo »
RAM memory at now days is cheap!
