Changing auto video format from default *.avi to others form
ttkh
Post by ttkh »
I would like to change the default auto video format from *.avi to other format. Please help
When do single movie you have the option to choose but when you search with the filter and there is option box to change to video and it doesn't allow me to choose the format and by default it go to avi? does anyone know how to change this option?
Thanks,
Quan
arielf
Post by arielf »
I do not speak English but I think you're looking for
in options >> images >> FFMPEG_FORMATS
help :
ZM_FFMPEG_FORMATS
Ffmpeg can generate video in many different formats. This option allows you to list the ones you want to be able to select. As new formats are supported by ffmpeg you can add them here and be able to use them immediately. Adding a '*' after a format indicates that this will be the default format used for web video, adding '**' defines the default format for phone video.
