missing /etc/zm/apache.conf
gian
Post by gian »
I had a division by zero error on my 1.24.2 console, and it is reported to be related to mixed versions, so I deleted all ZM folders and reinstalled from source from scratch.
Now I have apache.conf missing from /etc/zm, and cannot symlink it to zoneminder.conf.
What am I doing wrong?
thanks for your time,
-Gian
cordel
Post by cordel »
Apache config files are provided by the packagers and are not in the source since they are very specific to a distros installation. If you configured your ZM installation to mimic the package, you could use the config file from the package otherwise you need to manually configure Apache your self.
gian
Post by gian »
I know you'll laugh at me, but I found one apache.conf while googling for zoneminder, and I did a blind cut&paste job. It just works. Brrr!!!
-G
