how to access camera
packets
Post by packets »
Hi! I'm neebie to zoneminder so please bear with me. I'm using CentOS 5 and Zoneminder 1.24.2
I have installed zoneminder. I can access the console through x.x.x.x/zm. There is no access login so I cannot determine if I'm admin user or not. My question is:
1. How can I view the camera? Most tutorial only said just visit x.x.x.x/zm but all I can see is the console interface. Is there a page wherein I can only view cameras
2. I'm using PICO card, how could I verify if my card is working?
liviab
Post by liviab »
Did you add any camera (Add New Monitor)?
packets
Post by packets »
Yes. After I add a monitor. No camera. If it suppose to show up immediately, then why there's no camera appear? Here is some of the snippet on my dmesg:
ACPI: PCI Interrupt 0000:00:0f.0[A] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ 10
eth0: RealTek RTL8139 at 0xe0832000, 00:80:ad:74:79:f9, IRQ 10
eth0: Identified 8139 chip type 'RTL-8139C'
Linux video capture interface: v2.00
piix4_smbus 0000:00:07.3: Found 0000:00:07.3 device
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Host bridge needs ETBF enabled.
bttv: Bt8xx card found (0).
PCI: Enabling device 0000:00:10.0 (0104 -> 0106)
ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [LNKD] -> GSI 9 (level, low) -> IRQ 9
bttv0: Bt878 (rev 17) at 0000:00:10.0, irq: 9, latency: 132, mmio: 0xf4001000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: enabling ETBF (430FX/VP3 compatibilty)
bttv0: gpio: en=00000000, out=00000000 in=00f36fff [init]
i2c-algo-bit.o: (0) scl=0, sda=0
i2c-algo-bit.o: bt878 #0 [sw] seems to be busy.
bttv0: using tuner=4
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
voodoo3_smbus 0000:01:00.0: Using Banshee/Voodoo3 I2C device at e0948000
i2c-algo-bit.o: (0) scl=1, sda=1
i2c-algo-bit.o: (1) scl=1, sda=0
i2c-algo-bit.o: (2) scl=1, sda=1
i2c-algo-bit.o: (3) scl=0, sda=1
i2c-algo-bit.o: (4) scl=1, sda=1
i2c-algo-bit.o: I2C Voodoo3/Banshee adapter passed test.
i2c-algo-bit.o: DDC Voodoo3/Banshee adapter passed test.
input: PC Speaker as /class/input/input0
floppy0: no floppy controllers found
lp0: using parport0 (interrupt-driven).
lp0: console ready
ACPI: Power Button (FF) [PWRF]
My suspect is the pico card. When I check my syslog, I found something:
Jul 3 07:55:33 CAMERA zmc_dvideo[2052]: INF [Debug Level = 0, Debug Log = <none>]
Jul 3 07:55:33 CAMERA zmc_dvideo[2052]: INF [Starting Capture]
Jul 3 07:55:33 CAMERA zmc_dvideo[2052]: ERR [Capture failure for frame 0: Invalid argument]
Jul 3 07:55:33 CAMERA zmc_dvideo[2052]: ERR [Failed to prime capture of initial monitor]
Jul 3 07:55:33 CAMERA zmdc[2001]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Jul 3 07:56:13 CAMERA zmdc[2001]: INF [Starting pending process, zmc -d /dev/video]
Jul 3 07:56:13 CAMERA zmdc[2001]: INF ['zmc -d /dev/video' starting at 09/07/03 07:56:13, pid = 2055]
Jul 3 07:56:13 CAMERA zmdc[2055]: INF ['zmc -d /dev/video' started at 09/07/03 07:56:13]
Jul 3 07:56:13 CAMERA zmc_dvideo[2055]: INF [Debug Level = 0, Debug Log = <none>]
Jul 3 07:56:13 CAMERA zmc_dvideo[2055]: INF [Starting Capture]
Jul 3 07:56:13 CAMERA zmc_dvideo[2055]: ERR [Capture failure for frame 0: Invalid argument]
Jul 3 07:56:13 CAMERA zmc_dvideo[2055]: ERR [Failed to prime capture of initial monitor]
Jul 3 07:56:13 CAMERA zmdc[2001]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Jul 3 07:57:33 CAMERA zmdc[2001]: INF [Starting pending process, zmc -d /dev/video]
Jul 3 07:57:33 CAMERA zmdc[2001]: INF ['zmc -d /dev/video' starting at 09/07/03 07:57:33, pid = 2065]
Jul 3 07:57:33 CAMERA zmdc[2065]: INF ['zmc -d /dev/video' started at 09/07/03 07:57:33]
Jul 3 07:57:33 CAMERA zmc_dvideo[2065]: INF [Debug Level = 0, Debug Log = <none>]
Jul 3 07:57:33 CAMERA zmc_dvideo[2065]: INF [Starting Capture]
Jul 3 07:57:33 CAMERA zmc_dvideo[2065]: ERR [Capture failure for frame 0: Invalid argument]
Jul 3 07:57:33 CAMERA zmc_dvideo[2065]: ERR [Failed to prime capture of initial monitor]
Jul 3 07:57:33 CAMERA zmdc[2001]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
I'm using CentOS 5 and followed the procedure here http://www.zoneminder.com/wiki/index.ph ... figuration.
Anyone can suggest what to do next?
TIA
cordel
Post by cordel »
First what capture card do you have?
Is it really a type 77 card?
Where is the vodoo3 stuff coming from?
Can you view it in xawtv?
Can you do a screen grab (jpeg snapshot) in xawtv?
I think you might have the incorrect card configured potentially. If the card is not configured right, it will not work no matter what settings you put in ZM.
kocur2k4
Post by kocur2k4 »
hi packets, i seem to have the same capture card and the same errors.
did you find a solution?
