Upgrade database to 1.24.2
monex
Post by monex » Mon Jun 29, 2009 7:22 pm
when I try to upgrade the database from 1.24.1 to 1.24.2 I get the following error message:
Upgrading database to version 1.24.2
Loading config from DB
Saving config to DB
Can't find upgrade from version '1.24.1' at /usr/bin/zmupdate.pl line 883, <STDIN> line 2.
Maybe there are no changes but it would be nice if the tool in that case wouldn't exit with an error so that my wrapper script will work with that situation :)
Thank you
Monex
rdmelin
Post by rdmelin » Tue Jun 30, 2009 12:12 am
As a workaround you can edit /usr/bin/zmupdate.pl and add the block that upgrades from 1.24.1. Take a look, you will see that it's easy.
zoneminder
Site Admin
Post by zoneminder » Tue Jun 30, 2009 7:52 am
Yikes! Don't know how that got missed out and I have fixed/updated the tarball. Fortunately in this case it's just replacement of local monitor presets so nothing critical. It's easy enough to add manually if you look at db/zm_update-1.24.2.sql
Phil
monex
Post by monex » Tue Jun 30, 2009 6:09 pm
Thanks you for the fix,
Monex
Users browsing this forum: No registered users and 6 guests
