troubleshooting email sending - Ubuntu 9.04 zm 1.24
sgreszcz
Post by sgreszcz »
I downloaded the .deb file and installed zoneminder 1.24. All seems to be working OK, except I can't get the email alerting on alarms to work...
I am using ssmtp as my MTA, and I have tested that it is working using mutt to send an email and can see evidence of the sending in /var/log/mail.log
I can see that zoneminder is trying to generate the email:
Jun 19 15:41:02 247 zmfilter[11757]: INF [Creating notification email]
Jun 19 15:41:02 247 zmfilter[11757]: INF [Sending notification email 'ZoneMinder: Alarm - Cam-152 (5 - 5 3)']
Jun 19 15:41:02 247 zmfilter[11757]: INF [Attaching '/usr/share/zoneminder/events/1/152/011-capture.jpg]
but for some reason it isn't sending to localhost to be relayed out.
I have tried both perl methods as configured in zoneminder.
Can someone give me some suggestions on how to further troubleshoot this?
Thank you.
henriquejf
Post by henriquejf »
yes, i have a suggestion for you, an wiki article i have published that covers that and more; please tell me if you think that was somehow useful;
http://www.zoneminder.com/wiki/index.ph ... rver_32bit
luck !
Henrique Barbosa
Consultant
Juiz de Fora, MG - Brazil
rtm
Post by rtm »
Henriquejf - it was very helpful to me! Since I didn't have enough space to ftp all the images ZM is creating, your email fix now gets me something to alert me to any issues. Thanks!
(fyi - after playing around I found that %ED% and %ET% will put in the event date and time - I think that is useful to know when the alert happened versus counting that the email was delivered 'on time'. I tried to find where all of those codes may be, but alas, could not find any except what you posted. Thanks again!)
henriquejf
attachment zm codes
ok rtm, good to know ! the complete reference is in the documentation here:
http://www.zoneminder.com/wiki/index.php/Documentation
and what we want in it is
    %EI% Id of the event
    %EN% Name of the event
    %EC% Cause of the event
    %ED% Event description
    %ET% Time of the event
    %EL% Length of the event
    %EF% Number of frames in the event
    %EFA% Number of alarm frames in the event
    %EST% Total score of the event
    %ESA% Average score of the event
    %ESM% Maximum score of the event
    %EP% Path to the event
    %EPS% Path to the event stream
    %EPI% Path to the event images
    %EPI1% Path to the first alarmed event image
    %EPIM% Path to the (first) event image with the highest score
    %EI1% Attach first alarmed event image
    %EIM% Attach (first) event image with the highest score
    %EV% Attach event mpeg video
    %MN% Name of the monitor
    %MET% Total number of events for the monitor
    %MEH% Number of events for the monitor in the last hour
    %MED% Number of events for the monitor in the last day
    %MEW% Number of events for the monitor in the last week
    %MEM% Number of events for the monitor in the last month
    %MEA% Number of archived events for the monitor
    %MP% Path to the monitor window
    %MPS% Path to the monitor stream
    %MPI% Path to the monitor recent image
    %FN% Name of the current filter that matched
    %FP% Path to the current filter that matched
    %ZP% Path to your ZoneMinder console
cheers
Henrique Barbosa
Consultant
rtm
Post by rtm »
Thanks, and I found from reading another post that %ED% doesn't do anything - %ET% was giving date AND time.
dcbour
Post by dcbour »
Question...where would I find these defined - are they in a file...or the database. I would like to edit the variable presented so I can embed the authentication and skin selection in the string passed. I've grepped the files and checked through the database to no avail.
Dave
PacoLM
Thanks!
Post by PacoLM »
Hi henriquejf,
Followed your email setup guide with postfix, it worked perfect in my Guruplug system, thanks a lot.
PacoLM
