Page 1 of 1
Show Timeline link causes error in 1.24.1
Posted: Tue Apr 28, 2009 8:32 am
by acrohymn
Hi there can anyone explain how to over come this issue.
When I have a large event and click show timeline I get the following error:-
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 77 bytes) in /var/www/includes/database.php on line 125
I'm sure it is simple to increase memory some where but being a newby I'm not sure where or what.
Many thanks, John
Posted: Tue Apr 28, 2009 11:56 am
by cordel
Likely you need to increase your memory setting for php in you php config. Should be /etc/php.ini if not you'll have to search to locate it.
Posted: Mon Jan 04, 2010 4:04 pm
by lorsungcu
I have the same issue, but increasing the size does not change anything. Now zoneminder wont load at all; here's the error I'm getting:
Fatal error: Allowed memory size of 262144 bytes exhausted (tried to allocate 7680 bytes) in /usr/share/zoneminder/includes/database.php on line 147
Tried everything between 16M and 512M, nothing changed that error. Nothing sinister in the apache error logs. What/where should I be looking?
agree with cordel
Posted: Mon Jan 04, 2010 5:29 pm
by JohnnyLaww
I have to agree with cordel, this is a php configuration issue.
You need to edit your php.ini file and add/modify the following setting:
memory_limit = 32M
Most likely it is currently set to 16M or possibly even 8M depending on your OS and PHP version installed. As to where your php.ini file is located, again that will depend on which distro you have installed.
If you don't have access to your php.ini (ie, you are on a shared hosting provider) you can accomplish the same through an .htaccess setting:
php_value memory_limit 32M
Hope this helps..
Posted: Mon Jan 04, 2010 5:37 pm
by lorsungcu
Johnny - as stated, I've changed it to everything from 16M to 512M with no difference in outcome, I continue to get the fatal error. Here are the results of 'locate php.ini':
/etc/php5/apache2/php.ini
/usr/share/doc/php5-common/examples/php.ini-dist
/usr/share/doc/php5-common/examples/php.ini-paranoid
/usr/share/doc/php5-common/examples/php.ini-recommended
/usr/share/php5/php.ini-dist
/usr/share/php5/php.ini-dist.cli
I've tried changing all 3 (-dist, -dist.cli) values with no affect. Returning them to their defaults doesn't change anything, either. Here is the relevant bit of my php.ini file, am I missing something?
; Resource Limits ;
max_execution_time = 30     ; Maximum execution time of each script, in seconds
max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
;max_input_nesting_level = 64 ; Maximum input variable nesting level
memory_limit = 512M ; Maximum amount of memory a script may consume (16MB)
Like I said, I've tried 32M, tried 64, tried 96, 128 etc - nothing changes. I've reloaded apache, mysql and zm between each change. I've restarted the machine between some changes, no effect. I must be doing something wrong, but I dont know what.
PHP error
Posted: Mon Jan 04, 2010 5:57 pm
by JohnnyLaww
Okay,
I am pretty certain you will want to edit the php.ini located here:
Since you have already done so, lets verify that the changes have indeed been accepted.
Somewhere in your www root create a file called info.php
Insert this code:
<?php phpinfo(); ?>
Now browse to this file in IE or FF or whatever browser you are using.
Post the results here if you can, but more importantly verify the memory_limit settings.
John
Posted: Mon Jan 04, 2010 6:08 pm
by lorsungcu
Here are the bits that matter, let me know if you'd like to see something else:
System = Linux arccctv 2.6.31-16-server #53-Ubuntu SMP Tue Dec 8 05:08:02 UTC 2009 x86_64
Loaded Configuration File = /etc/php5/apache2/php.ini
additional .ini files parsed = /etc/php5/apache2/conf.d/mysql.ini, /etc/php5/apache2/conf.d/mysqli.ini, /etc/php5/apache2/conf.d/pdo.ini, /etc/php5/apache2/conf.d/pdo_mysql.ini
memory_limit = 512MB	512MB  (local / master values)
I'll go through the addition ini's and see if anything looks pertinent.
Posted: Mon Jan 04, 2010 6:21 pm
by lorsungcu
Reloaded apache again, didn't change anything, and it came back to life...going to try loading a large timeline view to see if i can make it break....
Timeline just loaded with 10k+ events. Seems to have fixed it, although I dont know what I did. Is upping the PHP memory limit the best solution? Am I going to break something else because that's so high now?
Posted: Mon Jan 04, 2010 6:52 pm
by JohnnyLaww
No, you should be fine, although 512M is a little overkill. You could be okay lowering it but seeing as how it's working now, you might as well just leave her alone.
