Maxopenfile reached & machine hangs zm problem ?
mitch
Post by mitch »
install the tool lsof then run it with the -p option with the pid of the zmwatch leaking( IE: lsof -p 19213) pastebin the results. My zmwatch doesn't leak like this but this should atleast list what file handles are leaking.
mastertheknife
Post by mastertheknife »
There is an easier way:
ls /proc/PID/fd | wc -w
mastertheknife.
mitch
Post by mitch »
wc -w prints the number of words and is absolutely useless. But ls -lah /proc/PID/fd will work just fine also.
maufacc
Post by maufacc »
mastertheknife wrote:There is an easier way:
mastertheknife.
ps -ef | grep zmwatch => 16150
ls /proc/16150/fd | wc -w => 7
lsof -p 16150 | wc -l => 40
cat /proc/sys/fs/file-nr
7264 0 42438
then kill -9 16150
6400 0 42438
As I read, but not fully understand, there is a difference between file handles an file descriptors, and between open files (lsof) and allocate file descriptors
http://linux.derkeiler.com/Newsgroups/c ... /0186.html
http://linux.derkeiler.com/Newsgroups/c ... /0397.html
http://www.netadmintools.com/part295.html
Thank you for your prompt response.
christiangraves
Post by christiangraves »
Hello, I am experiencing identical errors. I followed maufacc's steps and killing zmwatch brought the system back to life.
root@camera:/etc# ls /proc/1334/fd | wc -w
8
root@camera:/etc# lsof -p 1334 | wc -l
42
root@camera:/etc# cat /proc/sys/fs/file-nr
65664   0       65535
root@camera:/etc# kill -9 1334
992     0       65535
has anyone found a fix for this problem? if not, would a good workaround be to restart zoneminder daily with cron?
Thank you for the help!
johnnytolengo
error
Post by johnnytolengo »
hi all, here the same error the only way is delete the cookies from the browser and login again.
JT.
MarcoP
Post by MarcoP »
The following patch helped me a lot
http://www.zoneminder.com/forums/viewto ... 1462#61462
if you use this patch can you give a feedback too please?
jfkastner
Post by jfkastner »
saw your post about apache hangs - this is the same issue i guess?!
gotta be some apache problem though:
i can still SSH into my ZM machine, and use webmin (as root and also with the same account as ZM), as well as xterm etc -> the machine is NOT locked up, still recording etc, it is ONLY apache that stops responding (and therefore there have to be 'free' file handles/sockets etc)
also if you try ZM from a third machine you got the same problem (no apache response) as from the ZM server itself or your other client -> can't be a FF issue then (or sockets) on the client
guess it's difficult since there are so many apache versions/patch levels on so many OSs, but this thread (and the other) had some 16k views so this seems problematic to many others, hope we get this solved!
fleed
Post by fleed »
Another me too on this one. As soon as I kill zmwatch.pl the number of files used goes back to normal.
eletromidia:~# cat /proc/sys/fs/file-nr
1632	0	51140
eletromidia:~# kill 11613
1280	0	51140
1280	0	51140
eletromidia:~# /etc/init.d/zm stop
Stopping ZoneMinder: success
1056	0	51140
eletromidia:~# /etc/init.d/zm start
Starting ZoneMinder: success
1280	0	51140
It seems to me to be more related to zoneminder itself than apache. If it's relevant, I have mmap on... just a hunch, maybe it leaves a file handle open each time it shows a stream?
Other relevant details:
* I can ssh into the machine as root.
* Machine feels normal, no high cpu usage.
* Cannot change from root to a normal user. Get too many open files error message.
fleed
Post by fleed »
I think the problem is really related to mmap.
Have a look at /proc/$PID/maps and see a lot of references to mmap files:
eletromidia:/proc/12407# ps -ef | grep zmwatch
www-data 12407 12358  0 12:25 pts/0    00:00:17 /usr/bin/perl -wT /usr/local/bin/zmwatch.pl
root     17920 11144  0 15:50 pts/0    00:00:00 grep zmwatch
eletromidia:/proc/12407# grep mmap /proc/12407/maps | head -10
b58e8000-b58e9000 rw-s 00000000 00:10 154456     /dev/shm/zm.mmap.5
b58e9000-b58ea000 rw-s 00000000 00:10 154339     /dev/shm/zm.mmap.4
b58ea000-b58eb000 rw-s 00000000 00:10 154330     /dev/shm/zm.mmap.3
b58eb000-b58ec000 rw-s 00000000 00:10 154329     /dev/shm/zm.mmap.2
b58ec000-b58ed000 rw-s 00000000 00:10 154328     /dev/shm/zm.mmap.1
b58ed000-b58ee000 rw-s 00000000 00:10 154456     /dev/shm/zm.mmap.5
b58ee000-b58ef000 rw-s 00000000 00:10 154339     /dev/shm/zm.mmap.4
b58ef000-b58f0000 rw-s 00000000 00:10 154330     /dev/shm/zm.mmap.3
b58f0000-b58f1000 rw-s 00000000 00:10 154329     /dev/shm/zm.mmap.2
b58f1000-b58f2000 rw-s 00000000 00:10 154328     /dev/shm/zm.mmap.1
eletromidia:/proc/12407# grep mmap /proc/12407/maps | wc -l
6125
so, 6125 references to mmap in zmwatch.
And it just keeps going up...
jfkastner
Post by jfkastner »
todays tests on a ubu 8.04 client with FF 3.0.19 ran for >3 hours WITHOUT problems (in montage view - that's where all my problems came from!)
ZM server went up to 2000 open files and stayed there and never stalled (which is ubu 9.04 with zm 1.24.2)
BTW i do not use mapped memory but the 'old style' shared mem ...
jfkastner
Post by jfkastner »
on other clients than the above i found this helpful:
/etc/php5/apache2/php.ini settings (on the ZM server) changed to
max_execution_time = 120
max_input_time = 120
memory_limit = 19M
post_max_size = 12M
just to give PHP a bit more room to handle the picture/event data - maybe it's not apache freezing after all ?
sure this is trial and error but i'm getting somewhere ... BTW this is the PHP that came with ubu 9.04
NEWS EDIT: my FF37 client ran for more than 8 hours on montage w/o a stall - before the PHP change it ran only 5 minutes max (with 7 cams)
maybe PHP could not allocate any more memory and then it stalled apache
please someone else could try this out and let us know!
Maklaut
Re: Maxopenfile reached & machine hangs zm problem ?
Post by Maklaut »
mastertheknife
Re:
fleed wrote:I think the problem is really related to mmap.
6125
This issue (zmwatch.pl doesn't free file handles) was fixed in ZM 1.24.4.
mastertheknife
Kfir Itzhak.
