How to install zm 1.24.1 from source on Ubuntu 8.10 - SOLVED
timf
Post by timf »
see the much improved how to at the end of this thread kindly provided by jsylvia007
This also works for Ubuntu 9.04
http://www.zoneminder.com/wiki/index.ph ... ola-0.7%29
zoneminder
Site Admin
Post by zoneminder »
Thanks for this.It would be cool if you could add it to the distros section of the Wiki.
Phil
skumpic
Post by skumpic »
I followed this wiki.
To get it working in my ubuntu 8.10 i had to make this little changes:
1) After compiling FFMPEG i had to:
cd /etc/ld.so.conf.d
sudo gedit /etc/ld.so.conf.d/custom-libs.conf
Then add:
/usr/local/lib
and save.
Then
sudo ldconfig
2)
gedit .bashrc
And add at the end of the file:
LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH
Save. Exit and reboot.
3) Before configure zoneminder i had to edit zm/src/zm_rtsp.cpp at line 183 as follow (link: http://www.zoneminder.com/forums/viewto ... 9597#49597 )
diff -urN ZoneMinder-1.24.0.old//src/zm_rtsp.cpp ZoneMinder-1.24.0//src/zm_rtsp.cpp
--- ZoneMinder-1.24.0.old//src/zm_rtsp.cpp 2009-02-09 14:43:19.000000000 +0000
+++ ZoneMinder-1.24.0//src/zm_rtsp.cpp 2009-02-15 19:15:23.629245785 +0000
@@ -180,7 +180,7 @@
else
mUrl += '/'+mPath;
- mFormatContext = avformat_alloc_context();
+ mFormatContext = av_alloc_format_context();
mSsrc = rand();
See you
Skumpic
punk_ecas
Post by punk_ecas »
### These are my shared settings for 2GB of ram to support 6 color cameras at 640x480 and higher resolutions. I have a spread sheet which computes these numbers - seems to solve the problem. Edit and append to sysctl.conf as follows:
Can you send me your spread sheet that computes that numbers?
Thks
zoneminder_andre
Post by zoneminder_andre »
Hi there,
I've been struggling with the zoneminder 1.24.1 installation on Ubuntu Desktop 8.10 for about 2 days now :-(
I have done all of the above but when trying to start zm with
sudo zmpkg.pl start
I do get the following error:
/usr/local/bin/zmfix: symbol lookup error: /usr/local/lib/libavcodec.so.52: undefined symbol: av_gcd
Any help would be greatly appreciated!
BTW: ffmpeg gives me the following
FFmpeg version SVN-r17861, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  configuration: --enable-gpl --enable-postproc --enable-pthreads --enable-libfaac --enable-libfaad --enable-libmp3lame --enable-libtheora --enable-libx264 --enable-libxvid
  libavutil     49.15. 0 / 49.15. 0
  libavcodec    52.21. 0 / 52.21. 0
  libavformat   52.31. 1 / 52.31. 1
  libavdevice   52. 1. 0 / 52. 1. 0
  libswscale     0. 7. 1 /  0. 7. 1
  libpostproc   51. 2. 0 / 51. 2. 0
  built on Mar  7 2009 10:19:50, gcc: 4.3.2
At least one output file must be specified
When building ffmpeg from the latest sources the option "--enable-swscale" did not work.
Is that a problem?
Thanks in advance!!!!
André
[/code]
zoneminder
Site Admin
Looks like the latest ffmpeg has made swscale the default now. I'm not sure what your first error relates to, other than it is ffmpeg related, but will have a look.
Can you confirm you don't have any old copies of ffmpeg libraries etc lying around?
Phil
zoneminder_andre
I am pretty sure ... since it was a clean 8.10 installation.
Anyhow, how would I get rid of all ffmeg libraries to install compile it from scratch?
Thanks in advance!
André
zoneminder
Site Admin
I think you can just 'make uninstall' but have not actually done it lately.
Phil
newvisionantenna
Post by newvisionantenna »
I run make uninstall-libs then make uninstall. It will say some directories couldn't be deleted. I just double check them and every time I rebuild I have no issue's.
Check your inbox, sent you that firmware.
jsylvia007
Post by jsylvia007 »
I'm able to configure and "make" perfectly fine...
When I try "make install" i get this:
Making install in src
make[1]: Entering directory `/root/zm/src'
make[2]: Entering directory `/root/zm'
make[2]: Leaving directory `/root/zm'
make[2]: Entering directory `/root/zm/src'
make[3]: Entering directory `/root/zm'
make[3]: Leaving directory `/root/zm'
test -z "/usr/local/bin" || @MKDIR_P@ "/usr/local/bin"
/bin/bash: @MKDIR_P@: command not found
make[2]: *** [install-binPROGRAMS] Error 127
make[2]: Leaving directory `/root/zm/src'
make[1]: *** [install-am] Error 2
make[1]: Leaving directory `/root/zm/src'
make: *** [install-recursive] Error 1
This is a vanilla 8.10 install, following the above guide.
treesloth
an error
Post by treesloth »
An error occurs during make
make[2]: *** [zmc] Error 1
make[2]: Leaving directory `/home/tristan/ffmpeg/zm/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/tristan/ffmpeg/zm'
make: *** [all] Error 2
I will proceed and see if it compiles though
Blazer
Post by Blazer »
those errors with @ are autoconf aliases, sometimes you can fix by running:
autoconf
automake
and then trying to make again.
jsylvia007
@ Blazer - You were correct. that fixed my issues.
I'm in the process of redoing this from scratch, because the above steps do leave out some important things on a fresh ubuntu 8.10 server. The order is a little off as well...
But, wouldn't you know it... SVN.MPLAYERHQ.HU is offline, so i'm dead in the water until that comes back up. Grrr.
craver84
Post by craver84 »
same problem....
jsylvia007
18 hours later and its still down... This is not good. So much for wrapping this up before the weekend gets here.
Does anyone know what is going on?
