Italian translation: use $zmSlangStop, not $zmSlangStopp ...
If you would like to check the status of a language, volunteer to do a translation, or highlight or correct a problem in one of the existing language files then post here.
marcolino
Post by marcolino » Mon Jun 05, 2006 9:17 am
Please, check the console status page, I suppose it now uses
$zmSlangStopped = 'Fermo-immagine';
variable, and not
$zmSlangStop = 'Stop';
, which is the correct translation for the status of the server (though I think we could translate it as 'Arrestato', which sounds more italian ... ;-). Seeing 'Fermo-immagine' is quite deceptive, and does not give a good image of the whole package, which is nonetheless very impressive.
My best regards and kudos to everybody !
Marcolino
zoneminder
Site Admin
Post by zoneminder » Fri Jun 09, 2006 11:32 am
I'm not sure I exactly understand. It uses Stopped to express the system state, are you saying I should change what this is in the Italian language file?
Phil
marcolino
Post by marcolino » Fri Jun 09, 2006 12:12 pm
zoneminder wrote:I'm not sure I exactly understand. It uses Stopped to express the system state, are you saying I should change what this is in the Italian language file?
I think so. In Italian, "Fermo Immagine" means "Still Image", "Arrestato" means "Stopped".
zoneminder
Site Admin
Post by zoneminder » Fri Jun 09, 2006 12:37 pm
Ok, no problem. I will correct that.
Phil
marcolino
Post by marcolino » Fri Jun 09, 2006 12:49 pm
Good. Thanks.
And kudos for Your work !
sugacapra
Post by sugacapra » Tue Sep 26, 2006 12:41 pm
marcolino wrote:Good. Thanks.
doh
if is an old string maybe is not my error, but if is a new one then
appear that i've misunderstood the string while translating, sorry about it.
p.s.
Marcolino pls. may you check the version of the translation?
