Page 1 of 1
Uncomplete german translation?
Posted: Thu Jun 17, 2010 9:26 am
by Nukem36
High!
in ZM 1.24.2 it seems to me that a lot of translations are missing. Especially explaining texts are displayed in english only in the optins dialog.
- are these texts translateable?
- if yes: is there a howto what to download for translation and howto produce the translated version?
If so: I'll do my best to complete the german translation to the newest version and send you back the files.
Regards
Nukem36
Re: Uncomplete german translation?
Posted: Sun Jul 31, 2011 8:14 pm
by tijuca
old thread but I will warm it up :wink:
Nukem36 is right, there are a lot the non translated strings in 1.24.2. This release is still in Debian Squeeze so many of german Squeeze user will see this. Can someone answer the question from Nukem36?
I don't know if he is still reading here, so if there is some posibility I would also translate the missed strings.
Posted: Sun Jul 31, 2011 11:27 pm
by bb99
Pm Zoneminder with your ability
Posted: Thu Aug 04, 2011 6:35 pm
by tijuca
O.K. I started to translate the missed strings. It works for the "normal" entrys.
But I had a problem with the array for the translation in the options menu.
I used the given example.
//    'LANG_DEFAULT' => array(
//        'Prompt'  => "This is a new prompt for this option"
//        'Help'    => "This is some new help for this option which will be displayed in the popup window when the ? is clicked"
My first edit did'nt work.
$OLANG = array(
             'Prompt' => "Standardsprache im Webinterface",
             'Help' => "ZoneMinder erlaubt im Webinterface das Benutzen einer anderen Sprache wenn die Datei fuer die gewuenschte Sprache vorhanden ist. Diese Option erlaubt das Umstellen der Standardsprache welche mit dem Paket ausgeliefert wurde \(British English\) zu einer anderen Sprache.",
So if I change the locales the related entry in the options menu is empty. It seems that the array is accepted but the values are not used. Because I'm no PHP specialist I'm not able to make a little debuging output. Can someone help here.
Btw: If I take the given example there is also no text visible, so I don't think there is a problem with the translated text itself. The also available file for romanian with translations did'nt work.
Posted: Wed Jan 09, 2013 12:32 pm
by tomkolp
tijuca wrote:O.K. I started to translate the missed strings. It works for the "normal" entrys.
$OLANG = array(
Solved: http://www.zoneminder.com/forums/viewto ... 704#p78704
