Page 1 of 1
Arabic Translation
Posted: Fri Jan 02, 2009 6:46 am
by fadjar340
Dear All,
I want to help translating ZM to Arabic.
Is there any documentation to do this?
Also is it possible have multi language in the ZM?
Regards,
Fadjar340
Posted: Fri Jan 02, 2009 7:08 am
by cordel
The sticky above sort of explains it.
Posted: Fri Jan 02, 2009 3:40 pm
by fadjar340
As I understand the files of the language based on English and everybody read the test from left to right.
Since the Arabic language should read from right to left, is ZM have this feature? I mean change the reading direction...
Regards,
Fadjar340
Posted: Fri Jan 02, 2009 5:03 pm
by cordel
I honestly could not say as I'm not at all sure.
You might have a look in web/zm_lang_en_gb.php
Re: Arabic Translation
Posted: Mon Aug 27, 2012 5:21 am
by kie1988
Hi
where you able to translate to Arabic?
Posted: Thu Sep 19, 2013 6:00 am
by beiber
Yes very easiest and simple way is Google translator and you can also try Babylon translator. :)
